Старый 20.03.2012, 23:45   #1
mnt_dx is offline
mnt_dx
Axapta Retail User
1,748 / 158 (9) ++++++
Может помогут эти ссылки:
http://msdn.microsoft.com/en-us/libr...=ax.50%29.aspx
http://blogs.msdn.com/b/emeadaxsuppo...t-english.aspx
We have checked all of the standard SYS layer languages and the following languages are effected by the same issue:
es
es-mx
fr
fr-be
fr-ca
fr-ch
hu
is
it
it-ch
lt
lv
nl
nl-be
pl
pt-br
ru
sv
http://dynamicsuser.net/forums/p/46322/234245.aspx
The solution found. The error caused by Workflow System's and Execution Accounts' languages are not set to EN-US (In our case it was Turkish) . Change it to En-US and Resume all of the stopped instances. - надо менять язык
http://dynamicsuser.net/forums/p/43908/222047.aspx
За это сообщение автора поблагодарили: Ivanhoe (3), axm2017 (-7).
Старый 22.03.2012, 11:33   #2
Innokentiy is offline
Innokentiy
тут всё проще:
лэйблы элементов base enum WorkflowActorType замените их английскими нэймами.
Тоже самое с WorkflowPersonType.
И всё заработает
workflowax: Workflow history error – Stopped (error): Could not find user Blog bot DAX Blogs 0 11.02.2012 01:11
emeadaxsupport: Purchase Requisition Workflow in Dynamics AX 2009 fails with Stopped (error): Work item could not be created. Insufficient rights for user Blog bot DAX Blogs 0 18.11.2010 21:12
emeadaxsupport: Workflow error. Cannot resolve Workflow originator when user language is not English Blog bot DAX Blogs 0 04.06.2010 21:06
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 06:35.
