Старый 13.12.2011, 22:11   #1
sumitsaxfactor: Getting Ledger transactions in Ax 2012
Источник: http://sumitsaxfactor.wordpress.com/...ns-in-ax-2012/
Continuing with my blogs on Chart of accounts, in this blog, I will help you find the ledger transactions between a particular period.
In Ax 2009, it was pretty simple as you had to just loop through LedgerTrans table, Ax 2012 it has changed a bit.
Lets take an example and see how we can achieve this. Say you want to display following information in a report (for example purpose we will use infolog, I will cover reports in other blog entries).
Main account number – Main account name, Transaction date, voucher number, amount in base currency, amount in transaction currency and currency code.
To fetch transactions, now there are two tables that we need to use:
GeneralJournalEntry, GeneralJournalAccountEntry (There are more tables with GeneralJournalPrefix, I have not found there use yet but will update this post once I find more use of them).
staticvoid findLedgerTransactions(Args _args)
    MainAccount                         mainAccount; //Holds the main accounts
    GeneralJournalEntry                 generalJournalEntry; //Used to hold Ledger transactions
    GeneralJournalAccountEntry          generalJournalAccountEntry; //Used to hold Ledger transactions
    SubledgerJournalEntry               subLedgerJournalEntry; //Used to hold sub Ledger transactions (Like sales/purch invoice etc.)
    SubledgerJournalAccountEntry        subLedgerJournalAccountEntry;  //Used to hold sub Ledger transactions (Like sales/purch invoice etc.)
    DimensionAttributeValueCombination  dimAttrValueComb; //Used to store the combination of main accounts and dimensions
    whileselect AccountingCurrencyAmount, TransactionCurrencyAmount,  TransactionCurrencyCode
            from generalJournalAccountEntry
            join dimAttrValueComb
                where dimAttrValueComb.RecId == generalJournalAccountEntry.LedgerDimension
            join AccountingDate, JournalNumber from generalJournalEntry
                where generalJournalAccountEntry.GeneralJournalEntry == generalJournalEntry.RecId
                   && generalJournalEntry.AccountingDate == 017\2010
                   && generalJournalEntry.PostingLayer == OperationsTax::Current
                   && generalJournalEntry.Ledger == Ledger::current()
                join MainAccountId, Name from mainAccount
                    where mainAccount.RecId == dimAttrValueComb.MainAccount
                        && mainAccount.MainAccountId == ’130100′
            join subLedgerJournalAccountEntry
                where subLedgerJournalAccountEntry.GeneralJournalAccountEntry == generalJournalAccountEntry.RecId
                   && subLedgerJournalAccountEntry.LedgerDimension == generalJournalAccountEntry.LedgerDimension
                join Voucher from subLedgerJournalEntry
                    where subLedgerJournalAccountEntry.SubledgerJournalEntry == subLedgerJournalEntry.RecId
                       //&& subLedgerJournalEntry.Ledger == Ledger::current()
        info(strFmt("%1-%2, %3, %4, %5, %6, %7, %8", mainAccount.MainAccountId, mainAccount.Name,
                    generalJournalEntry.AccountingDate, subLedgerJournalEntry.Voucher,
                    generalJournalAccountEntry.TransactionCurrencyCode, generalJournalAccountEntry.TransactionCurrencyAmount,
                    generalJournalAccountEntry.AccountingCurrencyAmount,
                    generalJournalEntry.JournalNumber));
The output is as follows:
Jose Lorenzo: Change transactions date utility upgrade for Dynamics AX 2012 Beta VM Blog bot DAX Blogs 0 03.08.2011 09:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 09:25.
