Старый 30.11.2011, 23:11   #1
emeadaxsupport: Error "CryptoAPI not available" when browsing Enterprise Portal
Источник: http://blogs.msdn.com/b/emeadaxsuppo...se-portal.aspx
In Microsoft Dynamics AX 2012 consider the following scenario:
If, the Business Connector User account (bcproxy) specified under, System Administration > Setup > System > System service accounts if different from he user account associated with the application pool identity assigned to the web site hosting the Enterprise Portal (EP),
Then when a user browses the EP site, they see the followng error in the web browser:
An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
In the Application event logs on EP server, the following sequence of warnings and errors are logged:
Source: Dynamics .NET Business Connector 6.0
Event ID: 110
Level: Warning
Description:
6.0:
: An X++ exception has occurred.
CryptoAPI not available.
An error has occurred. Contact your administrator for further assistance.
Source: Microsoft Dynamics AX Enterprise Portal
Event ID: 1000
Level: Error
Description:
Microsoft.Dynamics.Framework.BusinessConnector
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.HandleException(String message, Exception exception, HandleExceptionCallback callback)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object[] paramList)
at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.WebSession.init(Object sessionHelper, Guid siteId, String localRelativeSiteUrl, Boolean isAxaptaSite, String masterClass, Boolean isPostBack, Boolean isPostSafe, Boolean isSharepoint)
at Microsoft.Dynamics.Framework.Portal.AxWebSession.InitializeWebSession(Guid siteId, String localSiteLink, Boolean isAxaptaSite, String masterClass, Boolean isPostBack, Boolean isPostSafe, Boolean isSharePoint)
at Microsoft.Dynamics.Framework.Portal.AxSharepointWebSession.InitWeb(HttpContext context, Boolean isPostBack)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.AddRef(ICacheContext context, Object lockobject)
To fix this either change the Business Connector Proxy user account in AX or the application pool identity via SharePoint Central Administration console (and not via IIS manager)
--author: Anup Shah --editor: Anup Shah --date: 30/Nov/2011
emeadaxsupport: "Unexpected error" when running a pop up on the Enterprise Portal for the first time Blog bot DAX Blogs 0 06.07.2011 17:11
emeadaxsupport: Kerberos authentication does not work when Enterprise Portal uses a non-standard port Blog bot DAX Blogs 0 14.02.2011 21:11
emeadaxsupport: Error "Cannot access a disposed object" when deploying AX 2009 Enterprise Portal on a SharePoint 2010 server Blog bot DAX Blogs 0 01.10.2010 20:05
emeadaxsupport: Enterprise Portal Web Parts show "Unable to render content" error Blog bot DAX Blogs 0 23.09.2010 19:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 23:08.
