MCT
сейчас общаюсь с англоязычной поддержкой Microsoft EMEA - и вот что они советуют по этому вопросу:
1) You could install the Debug Diagnostic Tools 1.2. This is a GUI tool that will set up a service to monitor the AOS. If the AOS crashes, it will dump all the application memory into a file and we can review this. I will add details on how to install and configure it below.
2) Another way would be to configure the built-in Windows Error Reporting (WER) to monitor the AOS. Please be aware that WER is only available in Windows Server 2008 (R2). Цитата:
You are right, that the standard WER messages do not supply enough info. But we have the option to set a new registry key which will cause WER to specifically monitor the AOS service and create a crash memory dump file (like DD 1.2 would) in case that the AOS service stops with an error.
For this you will have to create a registry key and then restart the whole machine, though. That is the reason why I would prefer to use DD 1.2 instead. You can find info on this here: http://blogs.msdn.com/b/emeadaxsupport/archive/2010/05/12/possibilities-to-create-memory-dumps-from-crashing-processes.aspx How to configure WER to create a memory dump of a crashing AOS service: You have to create the following registry key in order to monitor the AOS service: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Windows Error Reporting\LocalDumps\Ax32Serv.exe In addtion to that you will have to define the following value keys below this registry key: - DumpFolder (Define the patch where the dump files should be created, e.g. %LOCALAPPDATA%\CrashDumps) - DumpCount (Should be configured to 3-5. Once the number of dumps in the DumpFolder location exceed this value, the oldest will be replaced) - DumpType (Please configure to value 0. 0 = Custom dump, 1 = Mini dump, 2 = Full dump) - CustomDumpFlags (If DumpType is configured to 0, please set this value to 7015 decimal or 0x1B67 hexadecimal) Additional info on this can be found in the following MSDN article: http://msdn.microsoft.com/en-us/library/bb787181(VS.85).aspx
Sometimes there is a moment as you are awakening - when you become aware of the real world around you, - but you are still dreaming. - You may think you can fly but you do better not try. |
За это сообщение автора поблагодарили: Bega (1). |
Опции просмотра | |
