Старый 09.11.2011, 13:45   #2
микола777 is offline
микола777
Вот лог моей ошибки:
13:41:37| Info| Could not remove registry subkey HKEY_CURRENT_USER\SOFTWARE\Microsoft\MSCRMClient\AllowList. Cannot delete a subkey tree because the subkey does not exist.
13:41:37| Info| Executing Uninstall action: Microsoft.Crm.Config.Client.DeleteUserApplicationFilesAction
13:41:37| Info| Executing Uninstall action: Microsoft.Crm.Config.Client.DeactivateAddin
13:41:37|Verbose| Method exit: Microsoft.Crm.Config.Client.ClientConfig.Reset| System.Collections.Hashtable
13:41:37|Verbose| Method entry: Microsoft.Crm.Config.Client.ClientConfig.SetConfigurationControlRegistryValues
13:41:37|Verbose| Method exit: Microsoft.Crm.Config.Client.ClientConfig.SetConfigurationControlRegistryValues
13:41:37|Verbose| Method exit: Microsoft.Crm.Config.Client.ClientConfig.ConfigurationExceptionHandler
13:41:37|Verbose| Method exit: Microsoft.Crm.Config.Client.ClientConfig.Install| System.Collections.Hashtable
13:41:37| Error| Configuration exception.System.Exception: Action Microsoft.Crm.Config.Client.InstallPstAction failed. ---> System.Runtime.InteropServices.COMException (0xC0000135): LaunchOutlookInstallerProcess failed.
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at Microsoft.Crm.Config.Client.InstallPstAction.Do(IDictionary parameters)
at Microsoft.Crm.Setup.Common.Action.ExecuteAction(Action action, IDictionary parameters, Boolean undo)
--- End of inner exception stack trace ---
at Microsoft.Crm.Setup.Common.Installer.Install(IDictionary stateSaver)
at Microsoft.Crm.Setup.Common.ComposedInstaller.InternalInstall(IDictionary stateSaver)
at Microsoft.Crm.Setup.Common.ComposedInstaller.Install(IDictionary stateSaver)
at Microsoft.Crm.Config.Client.ClientConfig.Install(IDictionary data)
at Microsoft.Crm.Config.Client.ClientConfig.Run()
13:41:37|Verbose| Configuration Failed
13:41:37| Info| We were unable to successfully configure Microsoft Dynamics CRM for Outlook:
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Jim Wang: Software Advice: 15 Favourites Microsoft Dynamics CRM Industry Solutions Blog bot Dynamics CRM: Blogs 2 26.08.2010 02:09
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM Client for Outlook Blog bot Dynamics CRM: Blogs 0 30.05.2009 12:05
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Часовой пояс GMT +3, время: 16:26.
