Старый 26.09.2011, 13:11   #1
axblog4u: Dynamics AX2012: Table Full Text Indexes
Источник: http://axblog4u.wordpress.com/2011/0...-text-indexes/
Microsoft Dynamics AX 2012 provides full-text functionality that enables Microsoft Dynamics AX to search business data over a large volume of text data or documents.
Please refer the following link which explains on the same.
http://dynamicsaxgyan.wordpress.com/.../#comment-203/
Also refer ‘AX Wonders’ blog which explains on setting up ‘Full Text Index’ Setup in SQL Server 2008 R2
http://axwonders.blogspot.com/2011/0...ch-setup.html/
Example:
   Two important rules for creating Full Text Indexes
[Technet]
TableGroup property.
    A table can have a full text index only if the TableGroup property
    is set to Main or Group on the table.
    A full text index can only be created on a table with RecId index.
    So make sure 'CreateRecIdIndex' property flag on table is set to Yes
static void FullTextIndexesDemo()
    Query                   query = new Query();
    QueryBuildDataSource    queryBuildDatasource;
    QueryRun                queryRun;
    QueryBuildRange         queryRange;
    FullTextIndexesDemo     fullTextIndexes;
    queryBuildDatasource = query.addDataSource(tableNum(FullTextIndexesDemo));
    queryRange           = queryBuildDatasource.addRange(fieldNum(FullTextIndexesDemo,
					            AxVersion));
    queryRange.rangeType(QueryRangeType::FullText);
    [Technet] Space characters are treated as implicit Boolean OR operators.
    There is a space character in the string parameter in call
    queryBRange4.value("dynamics 0");.
    queryRange.value('dynamics 0');
    queryRun = new QueryRun(query);
    while (queryRun.next())
        fullTextIndexes = queryRun.get(tableNum(FullTextIndexesDemo));
        Debug::printTab(DebugPrintTab::ActiveX, fullTextIndexes.AxVersion);
Последний раз редактировалось Poleax; 26.09.2011 в 13:44. Причина: оформление
dax-lessons: Full Text Index in Dynamics AX 2012 – X++ Blog bot DAX Blogs 0 10.08.2011 02:17
Часовой пояс GMT +3, время: 16:04.
