Модератор
![]() Цитата:
![]() в Массовое развертывание клиентов Dynamics Ax 2009 использую на SMS Server рассылку группе в AD скрипта BAT - файл Код: @ECHO OFF set Distr_Ax=\\srv-fs-01\Deploy$\"Microsoft Dymanics Axapta"\ set PATH_dotNET="%SystemRoot%\Microsoft.NET\Framework\v3.5\vbc.exe" set PATH_Rollup="%ProgramFiles%\Microsoft Dynamics AX\50\Client\Log\SP1RU7UpdateLog.txt" set PATH_SP="%ProgramFiles%\Microsoft Dynamics AX\50\Client\Log\SP1UpdateLog.txt" set PATH_Ax="%ProgramFiles%\Microsoft Dynamics AX\50\Client\Bin\ax32.exe" @ECHO Disk Mapping @net use m: \\dc2\NETLOGON\scripts @ECHO Validating Install Package @if exist %PATH_Rollup% goto INSTALLED @if exist %PATH_SP% goto INSTALLRollup @if exist %PATH_Ax% goto INSTALLSP1 @if exist %PATH_dotNET% goto INSTALLAX :NOTNETINSTALLED @ECHO Installing .NET Framework 3.5 SP1 @START/w %Distr_Ax%"Ax_2009_ISO\_NET\Microsoft .NET Framework 3.5 Service pack 1.exe" /q /norestart :LOOPTRANS if not exist %PATH_dotNET% goto LOOPTRANS :INSTALLAX @ECHO Starting installation Dynamics Ax 2009 @START/w %Distr_Ax%"Ax_2009_ISO\Setup.exe" LogDir="%ProgramFiles%\Microsoft Dynamics AX\50\Client\Log\AX2009Log.txt" InstallPath="%ProgramFiles%\Microsoft Dynamics AX\50" InstallPath32Bit="%ProgramFiles%\Microsoft Dynamics AX\50" HideUI=1 AcceptLicenseTerms=1 InstallClientUI=1 ClientAosServer="DynamicsAx2009@Srv-axp-app-01" ClientLanguage=ru ClientHelpLanguages=ru ConfigurePrerequisites=1 :LOOPTRANS2 @if not exist %PATH_Ax% goto LOOPTRANS2 @GOTO INSTALLSP1 :INSTALLSP1 @ECHO Starting installation of Dynamics Ax 2009 SP1 @START/w %Distr_Ax%"SP1\axupdate.exe" LogDir=%PATH_SP% HideUI=1 AcceptLicenseTerms=1 InstallComponents=1 :LOOPTRANS3 @if not exist %PATH_SP% goto LOOPTRANS3 :INSTALLRollup @ECHO Starting installation of Dynamics Ax 2009 SP1 Rollup 7 @START/w %Distr_Ax%"RU7\axupdate.exe" LogDir=%PATH_Rollup% HideUI=1 AcceptLicenseTerms=1 InstallComponents=1 :LOOPTRANS4 @if not exist %PATH_Rollup% goto LOOPTRANS4 rem @GOTO COMPLETE :COMPLETE @ECHO Installation complete. @GOTO END :INSTALLED @ECHO SP1 Client Already Installed @GOTO END :END @ECHO Delete Disk Mapping @net use m: /delete /y @ECHO The end :) set PATH_Rollup= set PATH_SP= set PATH_Ax= set PATH_dotNET= set Distr_Ax=
This posting is provided "AS IS" with no warranties, and confers no rights. |
Теги |
ax2009 |
