Старый 26.05.2011, 23:11   #1
dynamics-ax: .Net Business Connector Not Recommend for AX 2012
Источник: http://dynamics-ax.blogspot.com/2011...recommend.html
Yesterday, I posted the following.: Microsoft Dynamics AX 2012 - System Architecture Overview
In that post, I gave a link to the following Microsoft TechNet article.: Microsoft Dynamics AX 2012 - System Architecture
Well one of the things that I did not highlight, but I wanted to have for it's own post was the fact that the following stands out on that article for TechNet.:
Note:
Use services and AIF to interact with the Microsoft Dynamics AX application. We recommend against using the .NET Business Connector to integrate with the Microsoft Dynamics AX application.
I think this really needs to sink in for people, and that everyone needs to take special attention to this note. The idea, is that services and AIF, which their end points are services, is the desired goal for how AX with interact with the outside world, and other LOB applications.
So, if you have a LOB application, or custom app that you want to integrate and work with AX, and it's business logic, the .Net BC is not the method that is desired with Microsoft Dynamics AX 2012.
It's still around, and for good reason, supporting all that IP that is already been developed around the .Net BC. However, I believe we can start to see the writing on the wall for this, and the design pattern, in that the .Net BC, I doubt, will exists beyond AX 2012 for such use.
Just an example of how Microsoft Dynamics AX 2012 is going to change how we implement, integrate and work with AX.
I think it's a great move, and one that has been the moving direction for a while, make everything SOA / WOA based, through services. Everything connecting through services. This sets up for a whole future of hybrid mix possibilities for where services and software lives within a companies total solution.
That's all for now, however I wanted to point this out specifically, after starting with yesterday post. More to come, as we dive deeper and deeper into different aspects of AX 2012.
Till next time!
"Visit the Dynamics AX Community Page today!"
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 09:57.
