Старый 13.11.2010, 21:12   #1
lcash: Refresh 4 – Hyper-V Services
Источник: http://blogs.msdn.com/b/lcash/archiv...-services.aspx
On the Refresh 4 VM you will find that the Hyper-V services are set to manual. This will result in the Time Sync service not starting. The end result of this is if you are running the second VM with Exchange then the Exchange Information Store won’t start because the time is out of sync between the two VMs.
So on AX5-W8R2-01 open the services
Locate the Hyper-V services. There are 5 services in total
Right click and select properties.
Change the start-up type to automatic so that when you re-start the VM the services will restart.
Hit apply and ok.
You should repeat this for the 5 services.
Now if you have had the second VM AX5-W8R2-02 started you are best to restarted the VM so that the machines can re-sync.
The other side effect of not having these services started is that when you try to shutdown the VM you might get a error message if the Hyper-V shutdown services is not started and you try to shutdown the machine from the Hyper-V console window.
Thanks to Kerry and Matt for pointing this one out.
Cheers
Lachlan
(Original post at http://blogs.msdn.com/lcash)
lcash: Refresh 4 – Using Remote Desktop Services Blog bot DAX Blogs 0 12.11.2010 01:11
lcash: Announcement of Microsoft Dynamics AX 2009 Demonstration VM – November 2010 Refresh Blog bot DAX Blogs 0 09.11.2010 19:04
lcash: No mouse with Win2008 RTM under Hyper-V Blog bot DAX Blogs 0 12.03.2010 01:06
lcash: Enabling Terminal Services on the demo VMs Blog bot DAX Blogs 0 25.11.2009 05:08
lcash: Additional disks with Refresh 2 and creating your own VMC or VM configuration Blog bot DAX Blogs 0 19.10.2009 17:05
Часовой пояс GMT +3, время: 01:51.
