Старый 13.09.2010, 21:47   #1
ipok is offline
ipok
В итоге получилось следующее:
Все работает, как всегда, БОЛЬШОЕ спасибо.
if (crmForm.all.regardingobjectid.DataValue != null && crmForm.all.regardingobjectid.DataValue[0].typename == "new_dogovor")
crmForm.all.new_dogovor_vstrecha.DataValue=crmForm.all.regardingobjectid.DataValue;
var dogovorid = crmForm.all.regardingobjectid.DataValue[0].id;
//НАХОДИМ ИД КЛИЕНТА
// Prepare variables for a contact to retrieve.
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>new_dogovor</entityName>"+
"<id>"+dogovorid+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>new_bizbizpdogovor</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Display the retrieved value.
else
client_id= resultXml.selectSingleNode("//q1:new_bizbizpdogovor").nodeTypedValue;
// НАХОДИМ ИМЯ КЛИЕНТА ПО ЕГО ИД
"<soap:Body>"+
"<entityName>account</entityName>"+
"<id>"+client_id+"</id>"+
"<q1:Attributes>"+
"<q1:Attribute>name</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
xHReq.send(xml);
alert(msg);
else
client_name= resultXml.selectSingleNode("//q1:name").nodeTypedValue;
//ДЕЛАЕМ НОВЫЙ ЛУКАП
var lookupData = new Array();
var lookupItem= new Object();
lookupItem.id = client_id;
lookupItem.typename = 'account';
lookupItem.name =client_name;
lookupData[0] = lookupItem;
crmForm.all.regardingobjectid.DataValue = lookupData;
Единственное, что приходит на ум, это через функцию получать ид и имя клиента.
может как-то можно еще оптимизировать ?
За это сообщение автора поблагодарили: mistah (1).
Старый 13.09.2010, 22:12   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Попробуйте так:
Код:
var client_id= resultXml.selectSingleNode("//q1:new_bizbizpdogovor").nodeTypedValue;
var clientname= resultXml.selectSingleNode("//q1:new_bizbizpdogovor").getAttribute("name");
Старый 14.09.2010, 10:26   #3
ipok is offline
ipok
Действительно ))
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Мелкомягкий CRM: Отображение в Lookup’е произвольного поля вместо основного атрибута Blog bot Dynamics CRM: Blogs 3 26.04.2010 19:10
mscrmblog: Mini Preview Window for Contact Lookup Field Blog bot Dynamics CRM: Blogs 0 10.03.2010 01:05
Jim Wang: CRM Filtered Lookup Multi Blog bot Dynamics CRM: Blogs 0 06.08.2009 06:11
mscrm4ever: Displaying a lookup with related entity fields Blog bot Dynamics CRM: Blogs 0 19.03.2009 07:05
Часовой пояс GMT +3, время: 23:04.
