Старый 18.11.2003, 08:38   #1
AlEr is offline
AlEr
"As you can see of the SQL statement below which is the result of your code generated to the Oracle database, the SELECT'ED fields are being LOWERCASED. This is due to the nature of the GROUP BY and using functional indexes, that we need to use a function on the fields for the optimizer to be able to use the functional index, if defined.
Using GROUP BY with Axapta 3.0/Oracle, you need to do some UPPERCASE string manipulation on the variables which you want to show/print.
SELECT SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(A.DIMENSION),1,10),SUBSTR(NLS_LOWER(A.DIMENSION2_),1,10),SUBSTR(NLS_LOWER(A.DIMENSION3_),1,10),A.TRANSTYPE,SUBSTR(NLS_LOWER(B.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(B.CURRENCYCODE),1,3),SUBSTR(NLS_LOWER(B.ACCOUNTNAME),1,60)
FROM LEDGERTRANS A,LEDGERTABLE B
WHERE (SUBSTR(NLS_LOWER(A.DATAAREAID),1,3)=NLS_LOWER('DMO'))
AND (SUBSTR(NLS_LOWER(B.DATAAREAID),1,3)=NLS_LOWER('DMO'))
GROUP BY SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(A.DIMENSION),1,10),SUBSTR(NLS_LOWER(A.DIMENSION2_),1,10),SUBSTR(NLS_LOWER(A.DIMENSION3_),1,10),A.TRANSTYPE,SUBSTR(NLS_LOWER(B.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(B.CURRENCYCODE),1,3),SUBSTR(NLS_LOWER(B.ACCOUNTNAME),1,60)
ORDER BY SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(A.DIMENSION),1,10),SUBSTR(NLS_LOWER(A.DIMENSION2_),1,10),SUBSTR(NLS_LOWER(A.DIMENSION3_),1,10),A.TRANSTYPE,SUBSTR(NLS_LOWER(B.ACCOUNTNUM),1,10),SUBSTR(NLS_LOWER(B.CURRENCYCODE),1,3),SUBSTR(NLS_LOWER(B.ACCOUNTNAME),1,60)"
Или другой workaround - выводить print Table1::find().Field1; внутри цикла...
С уважением,
ALER
Разница NotInTTS и Found Logger DAX: База знаний и проекты 6 18.09.2008 12:35
gatesasbait: Reverse keyword on Select Statements Blog bot DAX Blogs 0 08.02.2008 00:10
while select ... group by dimension[i] Tiruvileijadal' DAX: Программирование 33 06.12.2007 17:11
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
group , но не by slava DAX: Программирование 9 21.05.2003 19:05
Часовой пояс GMT +3, время: 07:33.
