Старый 01.07.2010, 22:07   #1
Pawan's Ax blog: HOW To Do Debugging In AIF
Источник: http://pawansaxblog.blogspot.com/201...ng-in-aif.html
IF we want to do debugging in AIF then follow the following steps.This is for Inbound processing
1.Go to AOT->Classes->AIFInBoundProcessingService
2.Go to method runAsWrapper
3.Comment the following lines in method
// BP deviation documented
// runas(axaptaUserId,
// classnum(AifInboundProcessingService),
// staticmethodstr(AifInboundProcessingService, processAsUser),
// messageIdContainer);
and replace this with the following line
AifInboundProcessingService::processAsUser(messageIdContainer);
4. Make the processAsUser method public from private
public static void runAsWrapper(AifWindowsUser runAsUserId, container messageIdContainer)
AifGatewayQueue gatewayQueue;
userId axaptaUserId;
AifMessageId messageId;
int messageIdContainerIdx = 1;
AifMessage errorMessage;
AifInfoLog aifInfoLog;
SysExceptionLog exceptionLog;
aifInfoLog = new AifInfoLog();
try
// Convert to Axapta UserId
axaptaUserId = AifEndpointUser::getAxaptaUser(runAsUserId).Id;
new RunAsPermission(axaptaUserId).assert();
CodeAccessPermission::revertAssert();
Pawan's Ax blog: How To Delete All Transaction Data In Ax Blog bot DAX Blogs 4 15.06.2010 11:23
Pawan's Ax blog: How to run AIF job Blog bot DAX Blogs 0 19.04.2010 11:05
Pawan's Ax blog: Run AIF Without Active Directory Blog bot DAX Blogs 0 19.04.2010 11:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
Часовой пояс GMT +3, время: 20:15.
