Старый 25.06.2010, 02:05   #1
Dynamics AX Sustained Engineering: Bank Checks do not display the correct numerals when using the Italian Language
Источник: http://blogs.technet.com/b/dynamicsa...-language.aspx
Scenario:
If you print an Accounts Payable check using the Italian language the check numerals may print incorrectly.
Resolution:
To resolve this issue you can modify the Global class adding an Italian specific method to return the correct check printing.
1. In the AOT >> expand classes >> locate the Global Class.
2. Right Click the Global Class >> Choose New Method
3. Add the below code example which translates the Italian language
static TempStr numeralsToTxt_IT(real _num)
int numOfPennies = (decround(frac(_num), 2) * 100) mod 100;
real test = _num - frac(_num);
int numOfTenths;
str 20 ones[19], tenths[9], hundreds, thousands, millions, billions, trillions;
int64 temp;
str 200 returntxt;
real modOperator(real a1, real a2)
int tmpi;
real tmp1, tmp2;
tmp1 = a1 / a2;
tmpi = real2int(tmp1);
tmp2 = tmpi;
return (tmp1 - tmp2)*a2;
real checkPower(real _test, int64 _power)
int64 numOfPower,numOfPowerOrig;
if (_test >= _power)
numOfPower = _test div _power;
numOfPowerOrig = numOfPower;
if (numOfPower == 1 && _power > 1000)
returntxt = returntxt + ' ' + substr("@SYS5437",0,2);
if (numOfPower >= 100)
temp = numOfPower div 100;
if(temp == 1 && _power >= 1000)
returntxt = returntxt + ' ' + hundreds;
else
returntxt = returntxt + ' ' + ones[temp] + ' ' + hundreds;
numOfPower = numOfPower mod 100;
if (numOfPower >= 20)
temp = numOfPower div 10;
returntxt = returntxt + ' ' + tenths[temp];
numOfPower = numOfPower mod 10;
if (numOfPower > 1)
returntxt = returntxt + ' ' + ones[numOfPower];
switch(_power)
case 1000000000 :
returntxt = numOfPowerOrig == 1 ? returntxt + ' ' + billions : returntxt + ' ' + "miliardi";
_test = modOperator(_test, 1000000000);
break;
case 1000000 :
returntxt = numOfPowerOrig == 1 ? returntxt + ' ' + millions : returntxt + ' ' + "milioni" ;
_test = modOperator(_test, 1000000);
break;
case 1000 :
returntxt = numOfPowerOrig == 1 ? "mile" : returntxt + ' ' + thousands ;
_test = modOperator(_test, 1000);
break;
case 100 :
_test = modOperator(_test, 100);
break;
return _test;
ones[1] = "@SYS26620";
ones[2] = "@SYS26621";
ones[3] = "@SYS26622";
ones[4] = "@SYS26626";
ones[5] = "@SYS26627";
ones[6] = "@SYS26628";
ones[7] = "@SYS26629";
ones[8] = "@SYS26630";
ones[9] = "@SYS26631";
ones[10] = "@SYS26632";
ones[11] = "@SYS26633";
ones[12] = "@SYS26634";
ones[13] = "@SYS26635";
ones[14] = "@SYS26636";
ones[15] = "@SYS26637";
ones[16] = "@SYS26638";
ones[17] = "@SYS26639";
ones[18] = "@SYS26640";
ones[19] = "@SYS26641";
tenths[1] = 'Not used';
tenths[2] = "@SYS26643";
tenths[3] = "@SYS26644";
tenths[4] = "@SYS26645";
tenths[5] = "@SYS26646";
tenths[6] = "@SYS26647";
tenths[7] = "@SYS26648";
tenths[8] = "@SYS26649";
tenths[9] = "@SYS26650";
hundreds = "@SYS26651";
thousands = "@SYS26652";
millions = "@SYS26653";
billions = "@SYS26654";
trillions = "@SYS101697";
test = checkPower(test, 1000000000);
test = checkPower(test, 1000000);
test = checkPower(test, 1000);
test = checkPower(test, 100);
if (test >= 20)
numOfTenths = test div 10;
returntxt = returntxt + ' ' + tenths[numofTenths];
numOfTenths = numOfTenths mod 10;
test = test mod 10;
if (test >= 1)
numOfTenths = real2int(test);
returntxt = returntxt + ' ' + ones[numOfTenths];
if (numOfPennies)
returntxt = '***' + returntxt + ' ' + "@SYS5534" + ' ' + num2str(numOfPennies,0,0,0,0) + '/100';
else
returntxt = '***' + returntxt + ' ' + "@SYS5534" + ' ' + '00/100';
return returntxt;
4. Add the below code in bold to the Classes\Global\numeralsToTxt
case 100 :
break;
return _test;
if(substr(xUserInfo::find().Language, 1, 2) !='it')
returntxt = Global::numeralsToTxt_IT(test);
return returntxt;
5. Save and Compile the code.
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 17:44.
