axaptapedia: Call-back methods
Источник: http://www.axaptapedia.com/Call-back_methods
============== Summary: New page: ==Call-back methods== Sometimes it is useful to call methods on the parent/caller of your class. If you are using the runbase framework you can call accessors methods from the form that c... ==Call-back methods== Sometimes it is useful to call methods on the parent/caller of your class. If you are using the runbase framework you can call accessors methods from the form that called your run method to initialize a new object. X++: public static void main(Args _args) { str callerName; ; if(_args.caller() != null) { callerName = _args.caller().name(); if(_args.dataset() == tableNum(BankAccountTrans) && formHasMethod(_args.caller(), identifierStr(bankAccountStatement)))//check the form for an accessor method for the statement { statement = _args.caller().bankAccountStatement();//get the bankStatment from the accessor method engine = new BankRecEngine(_args,_args.record(), statement.AccountId);//create a new runbase, fill params from the form calling this runbase if(engine.prompt())//ask the user for information { engine.run(); } } } } Источник: http://www.axaptapedia.com/Call-back_methods
