			axtools: Navigating the AX Application Explorer in Visual Studio
			Источник: http://blogs.msdn.com/axtools/archiv...al-studio.aspx
			============== In the last post we introduced the AX Application Explorer in Visual Studio, as the central hub for all AX development in Visual Studio. Now we will take a quick look at the navigation in the AX Application Explorer. Since the AOT is the AX developers home, we preserved the same UI look and feel, as well as the gestures commonly used by AX developers. You can navigate the AX Application Explorer using the keyboard just the same way you use the keyboard in the AOT. You can use type-ahead to search for elements, just like in the example below, where you see the selection on InventCostList after “inventcost” was typed in (in the status bar the type-ahead text is displayed). Using the left and right keys, you can expand the elements and inspect the details just like in the AOT: An important thing to understand about the AX Application Explorer is that it is not a superficial tool in Visual Studio. It integrates deep in the guts of Visual Studio and enables the presence of AX metadata in many of the existing Visual Studio components. Let’s select the AgreementHeader data source, and open the standard Properties Window. The Property Window shows: Yes, that’s right, you can think of it as Visual Studio itself being connected to the AX metadata repository, and the AX metadata being exposed in Visual Studio. To be continued… Источник: http://blogs.msdn.com/axtools/archiv...al-studio.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
			 Модератор
Хотя так уже никто его не называет.  |
![]() То есть - в 2009ом тебе приходится руками писать класс, который через .net business connector вызывает Аксаптовские классы и формы, а в 6ке - за тебя визард будет работать...  |
			Кстати - до сих пор не понял твоего энтузиазма по поводу перехода Аксапты на .net. Чего лично тебе это принесет ? (Кроме экономии 1 месяца в 25 месячном цикле подготовки разработчика на X++)
Меня сейчас здорово достает то, что разработку надо вести в двух-трех системах (внутри AX, VS, Excel и т.п.), отлаживать фиг знает как... А самое главное - нужны отдельные люди на X++ и на VS. Меня очень радует перспектива "все в одной инструментальной среде". И мне, честно говоря, все равно будут ли это врапперы или что-то еще... Да, пока не видно генератора форм из VS. Но движение - в правильном направлении.  |
			кстати, отчеты для SSRS пишутся тоже в VS
			 Модератор
			Простые отчеты удобнее делать для SSRS в Report Builder 2.0
	VS конечно ни кто не отменял, но не так интуитивно понятно как в Report Builder. Report Builder 3.0 только для SQL Server 2008 R2 P.S. Report Builder для пользователя  |
		#9 |
			Это я к тому, зачем еще может быть полезен AOT в VS
		#10 |
| Теги |
| tools, visual studio, перспективы |
