Dynamics CRM Tools: Who customize what and when?
Источник: http://mscrmtools.blogspot.com/2009/...-and-when.html
============== The customization feature of Microsoft Dynamics CRM 4.0 is well known for being one of its best strengths. However, it lacks one essential feature nearly: The monitoring of theses customizations. Indeed, it is impossible to know who does what in terms of customization and above what customizations were published. With plugins and the famous capabilities of customization, it is relatively simple to set up an event log of customizations in Microsoft Dynamics CRM 4.0. What you need is Plugins and one Custom Entity (let say “Customization Log”) Plugins Microsoft Dynamics CRM 4.0 provides us with several messages that allow us to track what is happening in terms of customizations the application. There are two types of messages:
They can give you two pieces of information:
In the case of imports, you can retrieve the customization file in the incoming properties (CompressedCustomizationXml) of the plugin context. So you can get the customization file during PRE stage (context.Stage == 10). Publish Messages They provide us with the list of entities that have been published (through the property ParameterXml of the plugin context). The messages are:
In the publish case, we only know the names of entities that are published. So, we must therefore export customization during POST stage to retrieve the customization file for the published items. The plugin Process In both cases (Import and Publish), we saw that we have the list of imported/published entities and the associated customization file. So, our plugin has only one thing to do: create a record of "Log customizations" entity type that will contain the following information:
BE AWARE of handling all exceptions because your imports will not work anymore if the plugin throw an exception NOTE : To compare two customization files and know what have been updated, you can use the CRM Customization Comparison Utility provided by Microsoft on the CRM Team Blog Источник: http://mscrmtools.blogspot.com/2009/...-and-when.html
