axStart: Cleaning up your Virtual companies
Источник: http://axstart.spaces.live.com/Blog/...C0A0!562.entry
============== Often consultants create virtual companies and forget to trough away the old data. This can become an issue when migration to a newer version of dynamics AX gets involved. For example if the CustTable & VendTable become virtual, have the old data no PartyID number and the unique index on this column can’t be enabled. The easiest way for removing these obsolete records is using sql script. I have added an example. Imagine a table collection with CustTable and VendTable. This table Collection is used in Virtual Company DMOV. Company DMO1 and DMO2 uses this virtual company. In case the records in CustTable and VendTable were not deleted for company DMO1 and DMO2, the next SQL script will help you: deleteFROM [AX2009_SP1_Dev].[dbo].[CustTable] where DATAAREAID in('DMO1','DMO2') deleteFROM [AX2009_SP1_Dev].[dbo].[VendTable] where DATAAREAID in('DMO1','DMO2') But what happens if the customer decides not to use the virtual company any more. You could throw it away but the data is not deleted in the Database (is this a bug?) I have created a general script that throws away the virtual company. declare @link_table nvarchar(255) declare @local_table nvarchar(255) declare @Statement nvarchar(300) declare table_list cursorforselect name fromsys.tables open table_list fetchnextfrom table_list into @link_table while@@FETCH_STATUS= 0 begin BEGINtry SET @Statement =N'delete from [AX2009_SP1_Dev].[dbo].['+ @link_table +'] where [DATAAREAID] in (''DMOV'',''ETC'')' print @Statement executesp_executesql@Statement endtry begincatch print @link_table +' has no DATAAREAID' endcatch fetchnextfrom table_list into @link_table end close table_list deallocate table_list Источник: http://axstart.spaces.live.com/Blog/...C0A0!562.entry
| Опции просмотра | |
