Старый 20.08.2009, 11:35   #1
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
попробуйте так:
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Fetch xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"&ltfetch mapping='logical'&gt&ltentity name='equipment'&gt&ltno-attrs/&gt&ltlink-entity name='new_equipment_contractdetail' from='equipmentid' to='equipmentid'/&gt&lt/entity&gt&lt/fetch&gt"+
"</Fetch>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","[URL]http://schemas.microsoft.com/crm/2007/WebServices/Fetch[/URL]");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
 var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
 alert(msg + "0");
// Process and display the results.
else
// Capture the result and UnEncode it.
var resultSet = new String();
resultSet = resultXml.text;
resultSet.replace('&lt;','<');
resultSet.replace('&gt;','>');
// Create an XML document that you can parse.
   var oXmlDoc = new ActiveXObject("Microsoft.XMLDOM");
   oXmlDoc.async = false;
// Load the XML document that has the UnEncoded results.
   oXmlDoc.loadXML(resultSet);
// Display the results.
   var results = oXmlDoc.getElementsByTagName('result');
      var msg = "\equipment Id\t\t\t\tequipment Name\r";
msg +="--------------------------------------------------------------------------------\r";
    for (i=0;i < results.length;i++)
     var idValue = results[i].selectSingleNode('./equipmentid').nodeTypedValue;
     msg += idValue +"\t";
    alert(idValue);
Экстремал и буду экстремать!
Блога
Старый 20.08.2009, 11:55   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
2 Slivka_83:
код работать не будет 100%.
Строка - xHReq.setRequestHeader("SOAPAction","URLhttp://schemas.microsoft.com/crm/2007/WebServices/Fetch/URL");
связанные сущности
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Получение свойств сущности DinDim Dynamics CRM: Разработка 3 06.02.2009 18:58
а можно к форме прикрутить Grid? if_maks Dynamics CRM: Разработка 4 03.01.2009 19:01
Автоматический апдейт сущности Maxoon Dynamics CRM: Функционал 7 28.05.2008 14:01
Можно ли завести CRM на локальном компе как Axapta или Navision ShadowFromXZone Dynamics CRM: Администрирование 6 16.06.2006 18:28
Часовой пояс GMT +3, время: 01:19.
