Afna CRM: Show custom notifications on Microsoft Dynamics CRM - upgrade
Источник: http://a-crm.blogspot.com/2009/07/sh...microsoft.html
============== Marco Amoedo created cool javascript function that displays custom warning messages in Microsoft Dynamics CRM 4.0. http://marcoamoedo.com/blog/show-cus...-dynamics-crm/ I liked the idea so much, that I took the script and upgraded pimped it. What it does? The function simply adds a notification on top of the form, like in the picture below. ![]() You can add multiple notifications with different icons. ![]() Update or delete previously added notifications or add new ones. This image shows (after Name onChange event) changed error text, updated third notification to info style and a new warning. Compare it with previous picture. ![]() How to use it? Step 1: Insert this code into form OnLoad event. /*============== addNotification function ============= Adds a message on the top of the entity form using the same visual style as Microsoft CRM. If function is called more than once, the messages are added at the bottom of the list If the message with same ID already exists, then the message is updated and not added to a list. It also supports deleting of previously added notifications. Put this function in the OnLoad event, so you can use it in all form and field events. Parameters: message - message to be shown to the user messageType - Type of the message: 1 - critical, 2 - info, 3 - warning notificationId - ID of the notification (needed for updating purposes) Created by: Marco Amoedo (http://marcoamoedo.com) - the idea and initial function Dejan Dular (http://a-crm.blogspot.com) - upgraded functionality (different icons, updating and deleting notifications) =======================================================*/ addNotification = function(message, messageType, notificationId) { var notificationsArea = document.getElementById('Notifications'); if (notificationsArea == null) { //Don't display message when deleting a notification. if (messageType != 4) { //Sorry. Notifications are not possible on this form. //Display a message box instead of notification. alert(message); } return; } var notificationDIV = document.getElementById('NotificationDiv_' + notificationId); //Delete the notification if (messageType == 4) { if (notificationDIV != null) { //Remove the notification notificationsArea.removeChild(notificationDIV); } return; } //Get the notification image. The default is info image. var notificationImage; switch (messageType) { case 1: notificationImage = '/_imgs/error/notif_icn_crit16.png'; break; case 2: notificationImage = '/_imgs/error/notif_icn_info16.png'; break; case 3: notificationImage = '/_imgs/error/notif_icn_warn16.png'; break; default: notificationImage = '/_imgs/error/notif_icn_info16.png'; } //Create notification var notificationTable = ' //Check if the notification with same ID already exists if (notificationDIV == null) { //Create a new notification var notificationHTML = '' + notificationTable + ' '; notificationsArea.innerHTML += notificationHTML; notificationsArea.style.display = 'block'; } else { //Update the notification. notificationDIV.innerHTML = notificationTable; } } /*============= END addNotification function ===========*/ Step 2: Run the following function when there is a need for a notification. addNotification(string message, int messageType, string notificationId) Parameters:
Thanks again to Marco Amoedo. Originally published by Dejan Dular Источник: http://a-crm.blogspot.com/2009/07/sh...microsoft.html
Опции просмотра | |
