Старый 30.07.2009, 01:06   #1
Dynamics Mobile: Configuring Permissions For Processing Mobile Documents in Microsoft NAV 2009
Источник: http://blogs.msdn.com/dynamicsmobile...-nav-2009.aspx
For a mobile document to process from the mobile document service to Microsoft Dynamics 2009, there are several permission settings in Microsoft Dynamics 2009 that you must configure. The permission settings vary depending on whether the mobile document service communicates with Microsoft Dynamics 2009 through an Application Server or a Web Service.
Note: For Microsoft Dynamics Mobile 1.5, the required permissions when using Application Server have changed from Microsoft Dynamics Mobile 1.1 and earlier versions.
Using Application Server
To process a mobile document in Microsoft Dynamics NAV 2009 through an Application Server, you must set up permissions in Microsoft Dynamics NAV 2009 on the following accounts:
  • Windows account of the mobile device user
  • Application pool identity that is used by the Mobile Document Service.
    Note: This was not required for Microsoft Dynamics Mobile 1.1 and earlier.
  • Logon account that is used by the Application Server component.
The following table includes the set up that is required for each account in Microsoft Dynamics NAV 2009 to process a mobile document.
Microsoft Dynamics NAV 2009 setupMobile user Windows accountDocument Service application pool identityApplication Server logon accountWindows loginyesyesyesRoles on the Windows loginThe roles that give permission to process information in the request document. For example, if you have a document type that creates customers, then the user’s Windows Login must be assigned the S&R-CUSTOMER, EDIT role, which is the standard role for users who have permission to create, modify, and delete customers.MOB-SERVER-NASMOB-SERVER-NAS
ALL
Role of each document type that Microsoft Dynamics NAV Application Server processes.
Mobile UseryesyesnoAssigned to the document typeyesnonoUsing Web Services
To process a mobile request document in Microsoft Dynamics NAV 2009 using Web services, you must set up permissions in Microsoft Dynamics NAV 2009 for the following accounts:
  • Identity of document handler that is used to process mobile request document. This can be the same as the document service’s identity.
Microsoft Dynamics NAV 2009 setupMobile user Windows accountDocument handler's identityWindows loginyesyesRoles on the Windows loginThe roles that give permission to process information in the request document. For example, if you have a document type that creates customers, then the user’s Windows Login must be assigned the S&R-CUSTOMER, EDIT role, which is the standard role for users who have permission to create, modify, and delete customers.noneMobile UseryesyesAssigned to the document typeyesno
apanko: Лаборатория Microsoft Dynamics 2009 mazzy Microsoft и системы Microsoft Dynamics 1 28.04.2009 14:31
jodonnell: Microsoft Dynamics NAV 2009 Upgrade Training Blog bot NAV: Blogs 0 30.01.2009 22:05
15 лет Microsoft Dynamics NAV в России, а сколько лет Вы работаете с системой? Fortune Полезное по Microsoft Dynamics 1 11.11.2008 15:36
Часовой пояс GMT +3, время: 13:04.
