SysDictCoder: Tricks with X++ embedded SQL
Источник: http://sysdictcoder.com/blog/tricks-...-embedded-sql/
============== There are some tricks that you can do in X++ SQL. They’re not really well known because they’re not suited for normal use and there are not many clues in the editor that they exist. But they do come in handy every now and then. Getting data without declaring a table variable It’s possible to get data from the database without declaring any table variables. It goes something like this: X++: static void Job3(Args _args ) { // No variables! ; print (select CustTable).AccountNum; pause; } If you use this there’s no Intellisense to help you look up the field name because the editor doesn’t know the type of the anonymous buffer. This technique is often used in exist() methods on tables. Getting a value from a field if you only know the field ID Sometimes you don’t know the exact field name but you do know a field ID. Even in cases like this it’s possible to write an X++ SQL statement without knowing any field names. Take a look at this example. X++: static void Job4(Args _args) { CustTable custTable; FieldId fieldId; ; fieldId = fieldNum(CustTable, AccountNum); // This could be passed as a method parameter select custTable; // Get first record print custTable.(fieldId); // Print account number select custTable where custTable.(fieldId) == '1101' ; // Where clause based on field ID print custTable.Name; pause; } Источник: http://sysdictcoder.com/blog/tricks-...-embedded-sql/
| Опции просмотра | |
