Чайный пьяница
Сообщение от slivka_83
![]() var passed = location.search;
phonecallid = passed.substring(5,41); var xml = "<?xml version='1.0' encoding='utf-8'?>"+ "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+ " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+ " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+ GenerateAuthenticationHeader()+ "<soap:Body>"+ "<Execute xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+ "<Request xsi:type='SetStatePhoneCallRequest'>"+ "<EntityId>"+phonecallid+"</EntityId>"+ "<PhoneCallState>Completed</PhoneCallState>"+ "<PhoneCallStatus>-1</PhoneCallStatus>"+ "</Request>"+ "</Execute>"+ "</soap:Body>"+ "</soap:Envelope>"; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject("Msxml2.XMLHTTP"); xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/200...ervices/Update"); xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xHReq.setRequestHeader("Content-Length", xml.length); xHReq.send(xml); // Capture the result var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display a confirmation message and open the updated contact. else { alert("Contact with id = "+phonecallid+" successfully updated."); window.open("/activities/phone/edit.aspx?id={"+phonecallid+"}"); } Замените xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Update"); на xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Execute");
