Роман Долгополов (RDOL)
Ну вот нашел старые BOL. Дырявая память похоже не подвела
Properties Pane (Dimension Editor Data View) Use the properties pane to display the properties of the object selected in the tree pane. To display the properties pane, click the Properties button .... Object Level .... Property Grouping Indicates whether the level contains member groups. Member groups can be used to satisfy the maximum limit of 64,000 members under a parent. To use member groups in this way, create a new level immediately above and identical to the level that exceeds the limit, and then set the new level's Grouping property to Automatic. For more information, see Member Groups. |
Теги |
olap, ограничения |
