Старый 04.04.2009, 03:19   #1
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites
Источник: http://blogs.msdn.com/solutions/arch...int-sites.aspx
If you already have SharePoint sites ( not based on EP site templates) and if you would like to use some of the AX web parts in those sites, it's easily doable in Microsoft Dynamics AX 2009.
Here are the steps to do.
(1) Integrating EP web parts to other sites requires install EP on the SharePoint server. To do that run setup and select Role Centers and Enterprise Portal component and go through the setup wizard. ( Uncheck the Auto create site option) since you don’t need a new site.
(2) Then you need to add a script manager to the master page (for example C:\Program Files\Common Files\Microsoft Shared\web server extensions\12\TEMPLATE\GLOBAL\default.master)of your site.
For example add
Just above the HTML tag ( Search for Setup->Internet -> Enterprise Portal and add the website and register the site with type “Web Parts only”. You also need to specify a company.
Once the script manager is added , EP is installed and the Site is registered in AX , then you can start using EP webparts on any SharePoint site.
For example, in the below screenshot, I am using AX web parts ( Cues and Unified worklist) in a wiki SharePoint site
Solutions Monkey: EP SSL ( https) Setup Blog bot DAX Blogs 0 23.10.2008 12:05
Solutions Monkey: How to alternate the background color of each row in Web Grid in EP 4.0? Blog bot DAX Blogs 0 12.01.2008 12:31
Solutions Monkey: EP Configuration - Single Web Server & Multiple AOS installations Blog bot DAX Blogs 0 28.10.2006 16:40
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Solutions Monkey: EP Web Part connection Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 00:43.
