Старый 10.03.2009, 23:05   #1
Microsoft Dynamics CRM Team Blog: Support for COUNT(DISTINCT) in Fetch XML queries
Источник: http://blogs.msdn.com/crm/archive/20...l-queries.aspx
We have made a couple of enhancements to the aggregate query feature of Fetch XML. These updates have shipped for version 4.0 as part of UR2 and for version 3.0 as documented in KB Article 960079. So far we only supported the count aggregate function which essentially did a count(*) on the base table of the entity.
We have enhanced this functionality to add a new aggregate operation countcolumn which now performs the SQL count operation for a given column. It also support the distinct keyword which only counts unique columns. If the distinct keyword is not specified with a countcolumn aggregate, its value defaults to false.
Here is a table that summarizes the Fetch aggregate types and its equivalent SQL translation:
CRM Fetch XML
SQL
SELECT COUNT(*) AS 'citycount' FROM Account
SELECT COUNT(address1_city) AS 'citycount' FROM Account
SELECT COUNT(DISTINCT address1_city) AS 'citycount' FROM Account
                                                     Key: Existing Feature, New Feature
Here are a couple of examples for using these features:
Query to return a count of all Accounts which have a county specified in their address.
1: Query to return a count of all Accounts which have a county specified in their address. 2: 3: 4: 5: 6:
Query to return a count of states in which we have an account. This uses the distinct keyword which counts a state only once.
1: 2: 3: 4: 5:
Thanks
Noor Merchant
Technorati Tags: Code,Tips and Tricks,XML,Dynamics CRM 4.0
Старый 12.03.2009, 12:16   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Полезная вещь. Жаль только для Fetch работает и интересно что будет, если такой фетч запрос попытаться преобразовать в QueryExpression?
Полезные ссылки по MS CRM. IgorF Dynamics CRM: Прочие вопросы 60 24.05.2013 16:19
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 4.0 Bookshelf Blog bot Dynamics CRM: Blogs 1 22.01.2009 04:46
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM E-mail Router Blog bot Dynamics CRM: Blogs 0 09.01.2009 06:03
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 01:45.
