LOG
log:
--- End of inner exception stack trace ---, Error, AbortRetryIgnore, Option1 13:27:41| Info| InputResult: Retry 13:27:41| Error| System.Exception: Action Microsoft.Crm.Setup.Exchange.InstallServiceAction failed. - --> System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at System.Int32.Parse(String s, IFormatProvider provider) at System.Diagnostics.PerformanceCounterLib.GetStringTable(Boolean isHelp) at System.Diagnostics.PerformanceCounterLib.get_NameTable() at System.Diagnostics.PerformanceCounterLib.get_CategoryTable() at System.Diagnostics.PerformanceCounterLib.CategoryExists(String machine, String category) at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName, String machineName) at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName) at Microsoft.Crm.Tools.Email.Agent.EmbeddedInstaller.Install(IDictionary stateSaver) at System.Configuration.Install.Installer.Install(IDictionary stateSaver) at System.Configuration.Install.AssemblyInstaller.Install(IDictionary savedState) at Microsoft.Crm.Setup.Exchange.InstallServiceAction.Do(IDictionary parameters) at Microsoft.Crm.Setup.Common.Action.ExecuteAction(Action action, IDictionary parameters, Boolean undo) Последний раз редактировалось Kosta100; 03.03.2009 в 15:22. Причина: bad |
Чайный пьяница
Сообщение от Kosta100
log:
13:26:31| Info| Property(S): MsiWin32AssemblySupport = 5.2.3790.3959 13:26:31| Info| Property(S): RedirectedDllSupport = 2 13:26:31| Info| Property(S): Privileged = 1 13:26:31| Info| Property(S): USERNAME = Mordi 13:26:31| Info| Property(S): COMPANYNAME = Diskal 13:26:31| Info| Property(S): DATABASE = C:\WINDOWS\Installer\3ad6033a.msi 13:26:31| Info| Property(S): OriginalDatabase = \\10.1.1.249\e\Exchange\i386\Exchange.msi 13:26:31| Info| Property(S): UILevel = 2 13:26:31| Info| Property(S): Preselected = 1 13:26:31| Info| Property(S): ACTION = INSTALL 13:26:31| Info| Property(S): ROOTDRIVE = D:\ 13:26:31| Info| Property(S): CostingComplete = 1 13:26:31| Info| Property(S): OutOfDiskSpace = 0 13:26:31| Info| Property(S): OutOfNoRbDiskSpace = 0 13:26:31| Info| Property(S): PrimaryVolumeSpaceAvailable = 20110880 13:26:31| Info| Property(S): PrimaryVolumeSpaceRequired = 53832 13:26:31| Info| Property(S): PrimaryVolumeSpaceRemaining = 20057048 13:26:31| Info| Property(S): PrimaryVolumePath = C: 13:26:31| Info| Property(S): SOURCEDIR =
при установке Email Router на CRM 4
#4 |
ya postil :
