Старый 25.12.2008, 10:39   #1
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Ну, собственно, нажмите View the Log file и он нам расскажет что за ошибка
Старый 25.12.2008, 12:50   #2
Kosta100 is offline
Kosta100
просьба помоч разобраться в логе
просьба помоч разобраться в логе :
System.Xml.XmlException: The 'DataSources' start tag on line 1 does not match the end tag of 'Report'. Line 4, position 12031.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
at System.Xml.XmlTextReaderImpl.ParseEndElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at Microsoft.Crm.SharedUtil.CreateXmlDocument(XmlTextReader reader)
at Microsoft.Crm.SharedUtil.CreateXmlDocument(String xml)
at Microsoft.Crm.Reporting.SRSReport..ctor(String xmlContent, String originalFilter, Boolean convertReportToCrm, ExecutionContext context)
at Microsoft.Crm.Reporting.SRSReport..ctor(String xmlContent)
at Microsoft.Crm.Setup.Server.Utility.ReportsUtility.OrganizationPublishReportsScaleGroup(IDbCommand command, Uri reportingUrl, String orgUniqueName)
at Microsoft.Crm.Tools.Admin.ImportOrganizationInstaller.Import(Guid organizationId, String organizationUniqueName, String organizationFriendlyName, String sqlServerName, String databaseName, Uri reportServerUrl, String privilegedUserGroupName, String sqlAccessGroupName, String userGroupName, String reportingGroupName, String privilegedReportingGroupName, ICollection`1 users, MultipleTenancy multipleTenancy)
04:56:14|Warning| Attempting to cancel a long running process: ProgressWizard. This might leave the data in an invalid state and the application might not function correctly.
Microsoft Dynamics CRM Team Blog: Building Rich-Client Dashboards for Microsoft Dynamics CRM with Windows Presentation Foundation Blog bot Dynamics CRM: Blogs 1 31.03.2009 13:24
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 4.0 Bookshelf Blog bot Dynamics CRM: Blogs 1 22.01.2009 04:46
Microsoft Dynamics CRM Team Blog: Reports for CRM 4.0 using SQL Server 2008 and Report Builder 2.0 Blog bot Dynamics CRM: Blogs 0 11.11.2008 08:05
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 16:20.
