Старый 23.01.2008, 22:30   #1
axStart: 2. Create HTML content in AX and deploy it with a Weblet
Источник: http://axstart.spaces.live.com/Blog/...C0A0!247.entry
When we want to use pictures in our records for the Enterprise portal. We have to add 2 fields to the related table. The first field needs to be derived from Bitmap the second from Image Format. There is a good example on Items/Setup/Presentation how to do that.
If we want to load HTML content in our record we use the class CCHTMLEditor. Example code
CCHTMLEditor editor;
editor = new CCHTMLEditor(‘record’,fieldnum(table,html),element);
editor.run();
webCaseStudy.reread();
webcasestudy_ds.refresh();
For displaying this HTML content we use a weblet that simply post the field
websession().writeTxt(this.getProp(extendedtypestr(HTML)));
For deploying the pictures we have to add the table also to the class SysEPDeployment method deployCompanyImages
axStart: Date methods in your Visual Studio Dynamics AX Report. Blog bot DAX Blogs 0 10.09.2008 23:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
axStart: Page definitions in AX Web development. Blog bot DAX Blogs 0 17.01.2008 03:30
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Часовой пояс GMT +3, время: 23:48.
