Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 25.10.2007, 18:01   #1
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Сообщение от ist Посмотреть сообщение
Ok but how I can distinctwish executeQuery() with and without filtering?
When "filter by field" is enabled i have to change JoinMode from OuterJoin to InnerJoin.
Maybe you cannot.
Try to look if a range exists on your field.
Старый 25.10.2007, 18:57   #2
ist is offline
ist
Maybe you cannot.
When it is filtering with "Filter By Field" strange why executeQuery did not invoke.
public void executeQuery()
    QueryBuildRange qbr;
    Query query = this.query();
    qbr = this.query().dataSourceTable(tableNum(ExtCodeValueTable)).findRange(fieldNum(ExtCodeValueTable, ExtCodeValue));
    if(qbr)
        query.dataSourceTable(tableNum(ExtCodeValueTable)).joinMode(JoinMode::InnerJoin);
    super();
The debuger does not stop on the breakpoint
Старый 25.10.2007, 18:57   #3
ist is offline
ist
Maybe you cannot.
    if(qbr)
    super();
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
axStart: Check if the table field is mapped. Blog bot DAX Blogs 0 07.03.2009 00:05
palleagermark: Set focus on a particular field on an EP page Blog bot DAX Blogs 0 27.11.2008 14:05
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
Часовой пояс GMT +3, время: 06:33.
