Старый 09.10.2007, 16:03   #1
konopello is offline
konopello
SAP
SAP
628 / 76 (4) ++++
если я правильно вас понял то вот
#define.channel("Optimum")
static void Optimum_ExportBalance(Args _args)
    TranslationChannel          translationChannel = TranslationChannel::find(#channel);
    CCADOConnection             connection = new CCADOConnection();
    CCADOCommand                command = new CCADOCommand();
    CCADORecordSet              recordSet;
    try
        connection.open(translationChannel.ADOConnectionString);
        command.activeConnection(connection);
        command.commandText(strfmt("DMT_Set_Balance '3077', '%1', 50000, 70000", date2str(systemdateget(),213,2,2,2,2,4)));
        recordSet = command.execute();
    catch(Exception::Error)
а вообще поищите поиском технология ADO уде неоднократно обсуждалась.
axStart: How to restore an AX 3.0 SQL 2000 backup in sql 2005 Blog bot DAX Blogs 0 12.02.2008 15:10
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 12:02.
