Старый 19.09.2007, 15:41   #1
Sada is offline
Sada
Программатор
Аватар для Sada
1,450 / 153 (8) ++++++
SELECT WITH SELECT_ORDER, NESTED_LOOP, FORCE_PLACEHOLDERS INDEXISHINT SUM(PostedQty), SUM(PostedValue), SUM(PhysicalValue), SUM(Deducted), SUM(Registered), SUM(Received), SUM(Picked), SUM(ReservPhysical), SUM(ReservOrdered), SUM(OnOrder), SUM(Ordered), SUM(Arrived), SUM(QuotationReceipt), SUM(QuotationIssue), SUM(PhysicalInvent), SUM(PostedValueSecCur_RU), SUM(PhysicalValueSecCur_RU), SUM(AvailPhysical), SUM(AvailOrdered) FROM InventSum GROUP BY InventSum.ItemId ASC USING INDEX ClosedItemDimIdx WHERE ((Closed = ???)) AND InventTable.ItemId=InventSum.ItemId AND InventTable.ItemId=InventSum.ItemId JOIN INDEXISHINT * FROM InventDim GROUP BY InventDim.InventLocationId ASC USING INDEX DimIdIdx WHERE InventSum.InventDimId = InventDim.inventDimId
Это запрос с таким кодом
 void executeQuery()
// > добавленный мной кусок  -->
QueryBuildDataSource BR;
Query q;
str s='';
QueryBuildRange findOrAddRange(int fNum){
 QueryBuildRange ret;
 ret=BR.findRange(fNum);
 if(!ret) ret=BR.addRange(fNum);
 return ret;
// > добавленный мной кусок  <--
    element.inventDimSetupObject().modifyQuery(inventSum_DS,inventDim_DS);
    q=InventSum_ds.query();
    BR=q.dataSourceNo(1).addDataSource(tablenum(InventTable));
    BR.relations(true);
    /*fItemGroupId     =findOrAddRange(fieldnum(InventTable,ItemGroupId));
    fModelGroupId    =findOrAddRange(fieldnum(InventTable,ModelGroupId));
    fDimGroupId      =findOrAddRange(fieldnum(InventTable,DimGroupId));
    fItemBuyerGroupId=findOrAddRange(fieldnum(InventTable,ItemBuyerGroupId));
    InventSum_ds.query(q); // пробовал     InventSum_ds.queryrun(new sysqueryrun(q)); - тот же эффект
info(inventsum_ds.query().dataSourceNo(1).toString());
    /*fItemGroupId.value(ItemGroupId.valueStr());
    fModelGroupId.value(ModelGroupId.valueStr());
    fDimGroupId.value(DimGroupId.valueStr());
    fItemBuyerGroupId.value(ItemBuyerGroupId.valueStr());
    super();
Как видно, InventTable в запросе есть
Использование семейства InventDimCtrl_Frm_* - 2 DS InventDim на одной форме Pavlo AKA Panok DAX: База знаний и проекты 5 22.12.2008 17:15
Название полей в форме запроса PavelSR DAX: Программирование 4 11.07.2007 17:19
Добавление источника к запросу на форме Lucky13 DAX: Программирование 1 21.05.2007 17:12
Пользовательские настройки: не отвязать таблицу в форме параметров запроса Gustav DAX: Функционал 6 23.06.2006 12:17
Значение пользовательского фильтра на форме vpa DAX: Программирование 7 27.10.2004 17:14
Часовой пояс GMT +3, время: 06:48.
