Перевел текст на англ. с помощью http://freetranslation.com/:
Again and again I was addressed on that whether it would not be possible to call the SQL ServerReporting services reports also without detour over a browser directly out of the DynamicsAX 4.0 menu. Unfortunately this is not possible in the standard. So I decided to write a small tool for this. With the SSRS Berichtsviewer Erweitung, the SQL servers ReportingServices reports can CROSSED opened become now directly 4.0 menu out of the Dynamics. Through it ability a simpler and above all generaler use of reports innerhalbvon Dynamics 4.0 CROSSED guaranteed become, CROSSED gives there it for the user no Unterschiedemehr between the proclamation of Dynamics 4.0 reports and SQL server ReportingServices reports.
Within Dynamics, 4.0 CROSSED become the SQL servers of Berichtsviewer gerendert new Reporting service report ineinem and represented. The SSRS Berichtsviewer expansion for Dynamics CROSSED 4.0 - version 0.1 can be downloaded here: SSRSReportingExtension_V0.1.zip(403,96 KB) the Downlaod some instructions to the use contain. Some questions are not supposed to be able to become to place nevertheless through the instructions answered please I this over the commentary function. Same applies also to Bugsoder Featurew?nsche for coming versions. Becomes no liability or guarantee on the correctness of the made statements given. The use results on own danger. Jinx's copyright © Mathias F??ler * CROSSED it blog http://starside.eu * Цитата:
Снова и снова ко мне обращались на эти, не будет ли возможно назвать SQL ServerReporting сообщениями об услугах также без обхода по браузеру непосредственно из DynamicsAX 4.0 меню. К сожалению это не возможно в стандарте. Таким образом я решил написать маленький инструмент для этого. С SSRS Berichtsviewer Erweitung, серверы SQL сообщения ReportingServices могут ПЕРЕСЕЧЕННЫЙ открытый становившийся теперь непосредственно 4.0 меню из Динамики. Через это способность более простое и прежде всего generaler использование сообщений innerhalbvon Динамика 4.0 ПЕРЕСЕЧЕННЫЙ гарантируемый становившийся, ПЕРЕСЕЧЕННЫЙ не дает там это для пользователя никакой Unterschiedemehr между провозглашением Динамики 4.0 сообщения и сервер SQL сообщения ReportingServices.
В пределах Динамики, 4.0 ПЕРЕСЕЧЕННЫЙ становятся серверами SQL Berichtsviewer gerendert новое сообщение об обслуживании Сообщения ineinem и представленный. SSRS Berichtsviewer расширение для Динамики ПЕРЕСЕКСЯ 4.0 - версия 0.1 может быть загружена здесь: SSRSReportingExtension_V0.1.zip (403,96 КБ) Downlaod некоторые инструкции к использованию содержат. Некоторые вопросы не должны быть в состоянии стать, чтобы поместить однако через инструкции, ответил пожалуйста на меня это по функции комментария. То же самое применяется также к Bugsoder Featurewьnsche для прибывающие версии. Не становится никакой ответственностью или гарантией на правильности сделанных данных утверждений. Использование заканчивается на собственной опасности. Авторское право проклятья © Матиас Фюслер * ПЕРЕСЕКЛО это blog http: // starside.eu * |
