Старый 27.07.2007, 17:30   #1
Arijit Basu: Post Ledger Transactions via X++
Источник: http://daxguy.blogspot.com/2007/07/p...ons-via-x.html
For beginner AX developers, I’m listing some codes which will help someone to post ledger transactions via X++ codes. This may be helpful to new Developers. [Level 200]
There are two ways to be considered when posting transactions:
1. Use the LedgerVoucher class and sub-classes API.
2. Use a journal Classes.
The Classes are:
• LedgerVoucher - Posting {LedgerVoucher harnesses the posting of multiple vouchers at a time. }
• LedgerVoucherObject - Voucher {The LedgerVoucher class holds all the vouchers in temporary storage.}
• LedgerVoucherTransObject – Transactions {Holds transactions in each Voucher}
Instantiation of LedgerVoucher
LedgerVoucher::newLedgerPost(_detailSummary,
_sysModule,
_voucherSeriesCode,
[_transactionLogType,
_transactionLogText,
_approveJournal,
_posting]);
Instantiation of LedgerVoucherObject
LedgerVoucherObject::newVoucher(_voucher,
[_transDate,
_sysModule,
_ledgerTransType,
_correction,
_operationsTax,
_documentNum,
_documentDate]);
Instantiation of LedgerVoucherTransObject
LedgerVoucherTransObject newCreateTrans(_ledgerVoucherObject,
_ledgerPostingType,
_ledgerAccount,
_dimension,
_currencyCode,
_amountCur,
_sourceTableId,
_sourceRecId,
[_qty,
_exchRate ,
_exchRateSecond,
_exchRatesTriangulation,
_markBridging ,
ProjLedger,
AmountMST ])
Sample Code
static void LedgerVoucherAPISample(Args _args)
LedgerVoucher _LedgerVoucher;
LedgerVoucherObject _LedgerVoucherObject;
LedgerVoucherTransObject _LedgerVoucherTransObject;
NumberSeq _NumberSeq;
Dimension _Dimension;
NumberSequenceCode _VoucherCode = 'Ledger_3';
LedgerAccount _Account = '110180';
LedgerAccount _OffsetAccount = '140270';
AmountCur _AmountCur = 12345.67;
ttsbegin;
_NumberSeq = NumberSeq::newGetVoucherFromCode(_VoucherCode);
_LedgerVoucher = LedgerVoucher::newLedgerPost(DetailSummary::Detail,
SysModule::Ledger,
_VoucherCode);
_LedgerVoucherObject = LedgerVoucherObject::newVoucher(_NumberSeq.voucher());
_LedgerVoucher.addVoucher(_LedgerVoucherObject);
_LedgerVoucherTransObject = LedgerVoucherTransObject::newCreateTrans(_LedgerVoucherObject,
LedgerPostingType::LedgerJournal,
_Account,
_Dimension,
CompanyInfo::standardCurrency(),
_AmountCur,
0,
0);
_LedgerVoucherTransObject.parmTransTxt("Arijit Basu");
_LedgerVoucher.addTrans(_LedgerVoucherTransObject);
_OffsetAccount,
_Dimension,
_AmountCur*-1,
0,
0);
_LedgerVoucher.end();
ttscommit;
The tables used are LedgerJournalName, LedgerJournalTable, and LedgerJournalTrans.
The steps are:
• Create a journal table record {Table\LedgerJournalTable}
• Create lines for each transaction to be posted {Table\LedgerJournalTrans}.
• Post the journal. {Classes\LedgerJournalCheckPost}
Sample Code
static void LedgerJournalCheckPostDemo(Args _args)
LedgerJournalTable _LedgerJournalTable;
LedgerJournalTrans _LedgerJournalTrans;
LedgerJournalCheckPost _LedgerJournalCheckPost;
ttsbegin;
//----Journal Header
_LedgerJournalTable.JournalName = 'Day1';
_LedgerJournalTable.initFromLedgerJournalName();
_LedgerJournalTable.Name = 'Daily Journal';
_LedgerJournalTable.insert();
//----Journal Line
_NumberSeq =NumberSeq::newGetVoucherFromCode(LedgerJournalName::find(_LedgerJournalTable.JournalName).VoucherSeries);
_LedgerJournalTrans.Voucher =_NumberSeq.voucher();
_LedgerJournalTrans.JournalNum =_LedgerJournalTable.JournalNum;
_LedgerJournalTrans.CurrencyCode =CompanyInfo::standardCurrency();
_LedgerJournalTrans.ExchRate =Currency::exchRate(_LedgerJournalTrans.CurrencyCode);
_LedgerJournalTrans.AccountNum ='110180';
_LedgerJournalTrans.AmountCurDebit =1000;
_LedgerJournalTrans.TransDate =Today();
_LedgerJournalTrans.OffsetAccount ='140270';
_LedgerJournalTrans.Txt ='Arijit Basu :)';
_LedgerJournalTrans.insert();
//----Journal Posting
_LedgerJournalCheckPost =LedgerJournalCheckPost::newLedgerJournalTable(_LedgerJournalTable,NoYes::Yes);
_LedgerJournalCheckPost.run();
ttscommit;
Info(StrFmt("Journal %1 is posted",_LedgerJournalTable.JournalNum));
Happy DAXing :)
Arijit Basu: AX 2009 Documents Blog bot DAX Blogs 0 30.08.2008 13:05
Arijit Basu: Microsoft Dynamics AX 2009 White Paper: Posting to the Ledger Blog bot DAX Blogs 1 04.08.2008 11:40
Arijit Basu: Copenhagen Convergence Review Blog bot DAX Blogs 3 07.11.2007 11:56
Dynamics AX: Microsoft Dynamics AX (DAX): Known Issues when upgrading to Microsoft Dynamics™ AX 4.0 - Arijit Basu | AX MVP Blog bot DAX Blogs 0 31.05.2007 03:30
Часовой пояс GMT +3, время: 11:59.
