Старый 16.06.2007, 11:20   #1
jerry-dynamics: sequentially numbered checks in the bank module
Источник: http://jerry-dynamics.org/2007/06/13...e-bank-module/
Your company wants to generate a number of sequentially numbered checks in the bank module. Which of the following is a requirement to allow sequentially numbered checks?
A: Set up a number sequence on the check layout.
B: Select Automatic check numbering in the Parameters.
C: Create a Check group and define the number sequence.
D: Select Fixed in the check numbering method.
Correct Answers: D
In the Check number method field, select the method to use for
generating check numbers. Select one of the following:
.Fixed Use this method when pre-printed checks exist. Before
using checks for payment, they must be created by clicking the
Create checks button in the Bank account window.
.Free Use this method when pre-printed checks do not exist.
Microsoft Dynamics AX 4.0 automatically proposes check
numbers when using checks for payment
jerry-dynamics: tax codes Blog bot DAX Blogs 0 16.06.2007 11:20
jerry-dynamics: checkbox Locked in Journal Blog bot DAX Blogs 0 16.06.2007 11:20
jerry-dynamics: Where can you drag and drop an extended data type to? Blog bot DAX Blogs 0 16.06.2007 11:20
Часовой пояс GMT +3, время: 07:58.
