Старый 31.05.2007, 22:00   #1
Dynamics AX: Quick Tip - Application Object
Источник: http://dynamics-ax.blogspot.com/2007...on-object.html
Have you ever had a need to run some code, or preform a task after each user's logon into Dynamics AX? Well I had just this need this past week and this is best done by using the Application.startupPost() method. In this method you can place code to call, say another class, to preform a task as each logon, better, after each logon into Dynamics AX.
This is the safest and preferred method of doing such a task. Well thought I would pass this along. Mostly a common knowledge thing, but sometimes it's hard to recall things that you have not touched, or even possibly thought about in a while.
check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Старый 01.06.2007, 08:46   #2
Хм... safest - это слишком.
См. также http://axapta.mazzy.ru/lib/startupcmd/#040
Dynamics AX: Application Benchmark Toolkit for Dynamics AX 2009 - Released Blog bot DAX Blogs 0 26.03.2009 01:08
Dynamics AX: SQL Quick tip - OpenQuery Blog bot DAX Blogs 0 01.11.2007 05:40
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
jinx: Absturz der Application Object Server Instanz beim Verlassen von Microsoft Dynamics AX Blog bot DAX auf Deutsch 1 02.10.2007 12:46
Часовой пояс GMT +3, время: 01:23.
