Старый 17.04.2007, 12:03   #1
Raven Melancholic is offline
Raven Melancholic
Аватар для Raven Melancholic
Самостоятельные клиенты AX
2,164 / 1296 (48) ++++++++
Тогда приведите ваш код формирования проводок (естественно, опустив несущественные детали).
Старый 17.04.2007, 12:12   #2
Андрей К. is offline
Андрей К.
Постигающий
152 / 10 (1) +
Код:
protected void postLedgerTrans(kasRRepRepairLine _repairLine)
    LedgerVoucher               ledgerVoucher;
    LedgerVoucherObject         ledgerVoucherObject;
    LedgerVoucherTransObject    ledgerVoucherTransObject;
    TransactionTxt              transactionTxt;
    LedgerBondClient_RU     ledgerBondClient;
    NumberSeq               numberSeq;
    Voucher                 voucherId;
    kasRRepEquipmentTable      equipmentTable;
    kasRRepEquipmentGroup      equipmentGroup;
    TransDate               transDate   = _repairLine.FinishDate;
    AmountMST               amount      = _repairLine.Rate * _repairLine.duration();
    numberSeq = NumberSeq::newGetNum(ProdParameters::numRefProdJournalVoucherId());
    voucherId = numberSeq.num();
    transactionTxt  = new TransactionTxt();
    transactionTxt.setType(LedgerTransTxt::None);
    transactionTxt.setDate(transDate);
    transactionTxt.setVoucher(voucherId);
    transactionTxt.txt(_repairLine.Note);
    ledgerVoucherObject = LedgerVoucherObject::newVoucher(voucherId,
                                                            transDate,
                                                            SysModule::System,
                                                            LedgerTransType::None,
                                                            NoYes::No);
    ledgerVoucher = LedgerVoucher::newLedgerPost(DetailSummary::Summary, SysModule::System, voucherId);
    ledgerVoucher.parmVoucherSeriesCode(numberSeq.parmNumberSequenceCode());
    ledgerVoucher.AddVoucher(ledgerVoucherObject);
    ledgerBondClient = ledgerVoucher.findLedgerVoucherObject().ledgerBondClient_RU();
    select firstonly equipmentTable
        index hint EquipmentIdx
    join equipmentGroup
        index hint EquipmentGroupIDX
        where   equipmentTable.EquipmentID      == _repairLine.EquipmentID &&
                equipmentGroup.EquipmentGroupID == equipmentTable.EquipmentGroupID;
    if (ledgerBondClient)
        ledgerBondClient.addNewLogObject();
    ledgerVoucherTransObject =
        LedgerVoucherTransObject::newCreateTrans(ledgerVoucher.findLedgerVoucherObject(),
                                                 LedgerPostingType::Allocation,
                                                 equipmentGroup.AccountNum,
                                                 Dimensions::emptyDimension(),
                                                 CompanyInfo::standardCurrency(),
                                                 amount,
                                                 _repairLine.RecId);
    ledgerVoucherTransObject.parmTransTxt(transactionTxt.txt());
    ledgerVoucher.addTrans(ledgerVoucherTransObject);
                                                 kasRRepRepairType::find(_repairLine.RepairTypeID).AccountNum,
                                                 -(amount),
                                                 _repairLine.RecId);
        if (ledgerBondClient.currentLogLength() == 2)
            ledgerBondClient.bondLastVRef2CurrentLog();
        ledgerBondClient.removeCurrentLogObject();
    ledgerVoucher.end();
Старый 17.04.2007, 12:24   #3
Raven Melancholic
На первый взгляд - код рабочий (если отвлечься от некоторых недочетов - например, отсутствие записи в лог). А сумма у вас случайно не нулевая? Или может в вышестоящем коде есть отмена транзакции?
Последний раз редактировалось Raven Melancholic; 17.04.2007 в 12:30.
Старый 17.04.2007, 12:30   #4
Андрей К.
Постигающий
152 / 10 (1) +
О какой сумме речь? (amount конечно не нулевая)
транзакции вообще не начинал в своем модуле
Последний раз редактировалось Андрей К.; 17.04.2007 в 12:37.
Старый 17.04.2007, 12:44   #5
Андрей К.
Постигающий
152 / 10 (1) +
Стоило указать у одного из TransObject'a
LedgerPostingType::Bank
и все стало разноситься
Немного об архитектуре разноски в ГК и проблеме корреспонденции счетов mazzy DAX: База знаний и проекты 29 02.05.2019 17:56
Просьба тем кто с Казахстана по разноске ГК Kuat DAX: Администрирование 4 30.07.2008 07:45
При повторном вызове linkActive проваливается в validateWrite(Строки общего журнала ГК) Lemming DAX: Программирование 6 25.10.2007 13:50
Ошибка (?) в периодических журналах ГК Anais DAX: Функционал 1 10.06.2005 13:20
sp5. Возможность получить Корр.счет ГК попроводкам клиента/поставщика без извращений studentLPC DAX: Функционал 20 27.05.2003 13:55
Часовой пояс GMT +3, время: 07:16.
