Старый 20.03.2007, 20:40   #1
mfp: Channel 9 Screencast - MorphX Best Practices
Источник: http://blogs.msdn.com/mfp/archive/20...practices.aspx
The new installment of AX screencasts is now available on Channel9. It is a 20 minute video on MorphX Best Practices in Dynamics AX 4.0 - one of my favorite topics!
Here is the link:
http://channel9.msdn.com/ShowPost.aspx?PostID=292988
I've attached the PowerPoint slide deck to this post. The deck contains a transcript of the talk in the slide notes.
Старый 20.03.2007, 20:40   #2
channel9: MorphX Best Practices in Dynamics AX
Источник: http://channel9.msdn.com/ShowPost.as...=292988#292988
?This screencasts show you how to use the X++ Best Practices inside Dynamics AX to build solid business applications.
It also shows you how you can create your own best practice rules.
Watch the screencast(WMV)
Старый 21.03.2007, 21:00   #3
casperkamal: Morphx Bespractices in Dynamics Ax - Screen cast Channel 9
Источник: http://casperkamal.spaces.live.com/B...CD63!252.entry
Watch out the screencast on "Morphx Best practices" to learn building solid business applications.
        (click here to open....)
............................................ Interesting
mfp: Survey opened: Microsoft Dynamics AX MorphX Tool Usage Blog bot DAX Blogs 1 01.05.2007 13:05
mfp: Dynamics Screencasts on Channel 9 Blog bot DAX Blogs 0 08.03.2007 00:44
mfp: Channel 9 screencast - Application Fundamentals Blog bot DAX Blogs 2 23.02.2007 23:03
mfp: Channel9 - AX screencast on Smart customizations Blog bot DAX Blogs 2 26.01.2007 05:45
mfp: Channel9 - AX screencast on Unit Testing Blog bot DAX Blogs 2 28.10.2006 23:31
Часовой пояс GMT +3, время: 22:25.
