Старый 17.01.2007, 16:02   #1
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Пожалуйста: приведенный ниже код копирует поле из SalesLine в ReqPO. Практически ваш случай.
// EVGGL, PT0616 -->
protected void TCHUpdatePlannedOrderSalesPoolId(ReqSetupDim _setupDim)
    ReqTrans            reqTrans;
    ReqTransCov         reqTransCov;
    ReqTrans            reqTransSettled;
    SalesPoolId         salesPoolId, oldSalesPoolId;
    ReqPO               reqPO;
    Map                 mapPlannedOrder;
    MapIterator         mi_PlannedOrder;
    Map                 mapReqTransReceipts;
    ReqTransCache       reqTransCache   = reqPlanData.reqTransCache();
    mapPlannedOrder = reqTransCache.mapPlannedOrder();
    mapReqTransReceipts = reqTransCache.findReceipts(_setupDim);
    if (! mapPlannedOrder || ! mapReqTransReceipts)
        return;
    mi_PlannedOrder = new mapIterator(mapPlannedOrder);
    mi_PlannedOrder.begin();
    while (mi_PlannedOrder.more())
        // ignore planned order coming from another cycle
        if (! mapReqTransReceipts.exists(mi_PlannedOrder.key()))
            mi_PlannedOrder.next();
            continue;
        reqTrans = mapPlannedOrder.lookup(mi_PlannedOrder.key());
        salesPoolId     = "";
        oldSalesPoolId  = "";
        if (reqTrans.CovQty && ! reqTrans.IsDerivedDirectly && ! reqTrans.IsForecastPurch &&
            (reqTrans.RefType == ReqRefType::ItemPlannedOrder || reqTrans.RefType == ReqRefType::BOMPlannedOrder))
            reqTransCov     = reqTrans.selectCovJoinTrans(true);
            reqTransSettled = reqTransCov.joinChild();
            while (reqTransCov)
                if (reqTransCov.Qty == 0)
                    continue;
                if (! reqTransSettled.InventTransId || ! reqTransSettled.RefId || reqTransSettled.RefType != ReqRefType::Sales)
                    // There cannot be any common relation
                    salesPoolId = "";
                    break;
                salesPoolId = SalesLine::findInventTransId(reqTransSettled.InventTransId).TCHSalesPoolId;
                if (! salesPoolId)
                    break;
                if (oldSalesPoolId && salesPoolId != oldSalesPoolId)
                    salesPoolId = "";
                    break;
                oldSalesPoolId = salesPoolId;
                next reqTransCov;
            if (salesPoolId)
                reqPO = reqTrans.reqPo(true);
                reqPO.TCHSalesPoolId = salesPoolId;
                reqPO.doUpdate();
Этот новый метод вызывается из ReqCalc.covCalc:
                                    this.TCHUpdatePlannedOrderSalesPoolId(setupDim);
                                    // EVGGL, PT0616 <--
                                ttscommit;
                            catch (Exception::Deadlock)
Разумеется, все это работает только в модели планирования "1:1". В противном случае вы получаете одну закупку, которая "закрывает" несколько заказов на продажу.
За это сообщение автора поблагодарили: wojzeh (1), shogel (1).
Старый 17.01.2007, 16:17   #2
Rimantas is offline
Rimantas
БОЛЬШОЕ СПАСИБО !!! . Только хочу переспросить - где поместить етот метод TCHUpdatePlannedOrderSalesPoolId , в какoй класс ?
Ещё раз СПАСИБО ! Римантас
Как правильно создать в коде X++ новый planned order (ReqPO, ReqTrans) rkorchagin DAX: Программирование 5 02.06.2016 18:00
Планирование номенклатуры с типом Основное средство AlexeyBP DAX: Функционал 19 29.01.2009 07:42
Отличия в строках ReqPO, почему одна строка появляется в форме а другая нет (Master Planning, Planned Orders) rkorchagin DAX: Программирование 8 21.02.2007 16:27
Планирование производственных операций Vikp DAX: Функционал 4 10.01.2006 15:43
Заказ -> Сводное планирование -> Изменение даты заказа ARRTEMka DAX: Функционал 8 14.02.2005 14:46
Часовой пояс GMT +3, время: 18:51.
