Старый 21.03.2003, 17:23   #1
dber is offline
dber
1. Пишут что да но я потом их редактировать не могу.
When you use the Web application wizard to create your own web application, you can use a template instead of creating a blank web app. Damgaard Axapta is delivered with 3 web applications. Select the Template checkbox in the Web applications form to make the web app available as template when running the wizard. The table below provides a description of the functionality you get from the specific templates. If you do not want to use templates when running the wizard, only the common files are created by the wizard.
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Web-приложение (вопрос экспертам) novic DAX: Программирование 9 24.12.2006 01:30
Web-приложение. Каких пользователей докупать sergeypp DAX: Администрирование 0 15.12.2006 16:03
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Solutions Monkey: EP Web Part connection Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 04:02.
