Старый 06.11.2020, 00:11   #1
crmtipoftheday: Tip #1386: I miss the green bar
Источник: https://crmtipoftheday.com/1386/i-mi...-the-green-bar
If you use the new solution import process at make.powerapps.com, you might miss the old green bar that told you how far the import had proceeded.
The good news is, while the green bar is gone, the underlying data that fed the bar is still there. You can query the importjob entity to see how much of the import is complete.
Run this query with the XrmToolBox and refresh until the import finishes.
Thanks to Ivan Kurtev for the suggestion.
Cover photo by Anshu A on Unsplash
crmtipoftheday: Tip #1103: Chart styling cheat sheet Blog bot Dynamics CRM: Blogs 0 08.04.2018 03:03
crmtipoftheday: Tip #1101: Add a scale break to charts Blog bot Dynamics CRM: Blogs 0 07.04.2018 04:03
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 12:36.
