Старый 15.02.2019, 00:37   #1
gl00mie is offline
gl00mie
3,684 / 5788 (200) ++++++++++
Post D365FO Platform Update 23 (7.0.xxxx) KB 4481230 bug fixes
Дата выпуска: 03.01.2019 (пока что обновление доступно лишь некоторым клиентам)
Список исправлений:
  • Issue 264098 Data Management
    Composite entity XSLT transformation not applied during export.
  • Issue 251763 Develop and customize
    Batch job may cause DuplicateKeyException errors
  • Issue 217263 Develop and customize
    Visual Studio Tools: Form part data sources (in form extension) are not visible in the data source lookup menu
  • Issue 259894 Office Integration
    Excel Add-in filter doesn't work for multi-byte (Japanese) characters
  • Issue 173758 Runtime
    NumberSequencesReferenceEntity - Import error
  • Issue 181709 Runtime
    DirPerson UpdateConflict saving worker
  • Issue 244432 Runtime
    Infolog error thrown when trying to view security configuration audit data: Cannot execute a data definition language command on Security object events view (SecurityObjectEventView).
  • Issue 259358 Runtime
    Formpart is not showing expected data for relation link after adding date field
  • Issue 261023 Runtime
    The URL Generator is returning Deep links with wrong menu-item type value
  • Issue 256462 Runtime
    Database Log displays wrong enum value for changes in PmfProductType enum
  • Issue 173851 System Administration
    Impossible to see all messages of the log in the batch job history when many records are processed
  • Issue 258108 System Administration
    Batch job maybe marked as complete before all tasks are completed
  • Issue 266396 System Administration
    Batch group server list having duplicate server Ids
  • Issue 237175 User Interface
    Personalized description field loses its values
  • Issue 254342 User Interface
    Playing a task guide should be done in the user's language, not the language the task guide was recorded with
  • Issue 261312 User Interface
    The discount percent is still applied when it is added and removed before leaving the field
  • Issue 259907 User Interface
    Embedded PowerApp Param() function is truncating leading zeros in string value
d365 for operations, d365fo
D365FO Platform Update 22 (7.0.5095) KB 4486423 bug fixes gl00mie DAX: Администрирование 0 15.02.2019 00:27
D365FO Platform Update 21 (7.0.5073) KB 4477851 bug fixes gl00mie DAX: Администрирование 1 14.02.2019 23:25
sinedax: 8.1.3 Platform Update 23 Installation Issue - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 02.02.2019 02:51
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
dynamicsaxse: December Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 04.01.2018 03:46
Часовой пояс GMT +3, время: 15:36.
