#4 |
Step 22: Configure the Financial Reporting database
Execute the following Script .\Initialize-Database.ps1 -ConfigurationFilePath .\ConfigTemplate.xml -ComponentName MR The script will do the following: a. Create an empty database named FinancialReporting. b. Map the users to database roles based on the following table. Step 23: Encrypt Credentials: On any client machine, install the encipherment certificate in the LocalMachine\My certificate store. Grant the current user read access to the private key of this certificate. Create the Credentials.json file, as shown here. { "AosPrincipal": { "AccountPassword": "Dynamo@123" }, "AosSqlAuth": { "SqlUser": "axdbadmin", "SqlPwd": "Dynamo@123" } } Dynamo@123 is the encrypted domain user password for the AOS domain user (local\axserviceuser). SqlUser is the encrypted SQL user (axdbadmin) that has access to the Finance and Operations database (AXDB), and Dynamo@123 is the encrypted SQL password. Copy the .json file to the SMB file share, \\AOS1\agent\Credentials\Credentials.json. Why this accounts and Password has to be encrypted? While deploying the Application from LCS ,the script checks the encrypted Passwords and Users.If this step is not executed Properly,the deployment will fail. Install Install the Microsoft Azure Service Fabric SDK before executing script Execute the below script to get encrypted Values.The Script has to executed 3 times to get the Value For AccountPassword Invoke-ServiceFabricEncryptText -Text Dynamo@123 -CertThumbprint 9A5A0A92E7C62CA65FF14E6F9C9ECE9F6B76FA1A -CertStore -StoreLocation LocalMachine -StoreName My | Set-Clipboard Execute the Script and open a notepad and ctrl+V to paste the encrypted Value For SQL USER Invoke-ServiceFabricEncryptText -Text axdbadmin -CertThumbprint 9A5A0A92E7C62CA65FF14E6F9C9ECE9F6B76FA1A -CertStore -StoreLocation LocalMachine -StoreName My | Set-Clipboard Execute the Script and open a notepad and ctrl+V to paste the encrypted Value For SQLPassword Invoke-ServiceFabricEncryptText -Text Dynamo@123 -CertThumbprint 9A5A0A92E7C62CA65FF14E6F9C9ECE9F6B76FA1A -CertStore -StoreLocation LocalMachine -StoreName My | Set-Clipboard Execute the Script and open a notepad and ctrl+V to paste the encrypted Value Now Update the 3 encrypted values in the Credentials.Json file Step 24:Setup SSIS To enable Data management and Integration workloads, SSIS must be installed on each of the AOS virtual machines. Complete the following steps on each AOS virtual machine.
To Setup the SSRS Machine refer the MS Document below https://docs.microsoft.com/en-us/dyn...rs-on-premises Step26 :Configure ADFS
Add-Type -AssemblyName System.Net $fqdn = ([System.Net.Dns]::GetHostEntry('localhost').HostName).ToLower() $domainName = $fqdn.Substring($fqdn.IndexOf('.')+1) Set-AdfsClaimsProviderTrust -TargetIdentifier 'AD AUTHORITY' -AlternateLoginID mail -LookupForests $domainName Once after the ADFS necessary scripts are executed ,Application group script should be execute .\Publish-ADFSApplicationGroup.ps1 -HostUrl https://ax.Local.com Now after successfully deployed the ADFS ,access the url in AOStype node https://adfs.local.com/adfs/.well-kn...-configuration This step is highly important to complete is successfully since the Dynamics on premise user access page opens based on the ADFS redirection Configuration. You successfully access the URL, a JavaScript Object Notation (JSON) file is returned that contains your AD FS configuration, and you will see that your AD FS URL is trusted. Step 27: Configure a connector and install an on-premises local agent Sign in to LCS, and open the on-premises implementation project. Select the Project Setting Tab Create a On Premise Connector and Edit the Configuration Details Download the Agent Installer and Verify that the zip file is unblocked. Right-click the file, and then select Properties. In the dialog box, select Unblock. Unzip the agent installer on one of the Service Fabric nodes of the OrchestratorType type. Enter the Configuration Details Execute the below script to get the configurations details .\Get-AgentConfiguration.ps1 -ConfigurationFilePath .\ConfigTemplate.xml Download the Configuration file and copy the file to the local agent folder In a Command Prompt window, run the following command by navigating to the folder that contains the agent installer. The user who runs this command must have db_owner permissions on the OrchestratorData database. LocalAgentCLI.exe Install C:\InfrastructureScripts\Local\LocalAgent-163366\LocalAgent-163366\localagent-config.json After the Local agent is successfully executed ,which will create 2 applications in Service Fabric On the Validate setup tab, select Message agent to test for LCS connectivity to your local agent. When a connection is successfully established, the page will resemble the following illustration.
Возможно сделать все. Вопрос времени Последний раз редактировалось sukhanchik; 02.09.2018 в 21:55. |
| Теги |
| d365fo, lbd |
