Старый 18.04.2017, 21:11   #1
organicax: TAM – Creating a new customer category hierachy
Источник: https://organicax.com/2017/04/18/tam...gory-hierachy/
If you are looking to setup trade allowance management then one thing you will do is create a grouping mechanism called the customer category hierarchy. This allows you do define a tree structure of categories to assigned customers. One you have done this it will help you find customer when you setup a trade allowance agreement or fund. The adding customers is manual it’s worth planning out ahead if you want a lot of hierarchies or a couple based on customer grouping. The thing to keep in mind is that with a trade allowance agreement you can switch the hierarchies and find the customer you want to add to that agreement. The fund is different if you want to use that to allocate a budget you can only pick from one hierarchy.
Here is a quick overview.
D365 1611 Update5 (7.0.4475.35138)
If you are looking for an AX2012 overview you can find it here.
Cheers
Lachlan
Filed under: Sales and marketing
organicax: TAM – Creating a new customer category hierarchy Blog bot DAX Blogs 0 18.04.2017 21:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
organicax: Creating a category based purchase order in AX7 Blog bot DAX Blogs 0 01.10.2016 04:15
organicax: Creating a one time customer Blog bot DAX Blogs 0 05.04.2016 11:11
Часовой пояс GMT +3, время: 22:57.
