Старый 02.11.2016, 01:11   #1
organicax: Number sequence wizard
Источник: https://organicax.com/2016/11/01/num...quence-wizard/
In a previous post we create a new legal entity. The next step in setup would be to initialize the number sequences for that company and review them as needed. You can manually create number sequences but you might want to first start with the wizard to populate them all and then go back and adjust the ones you need to adjust.
Here is a quick overview.
D365FO Update3 (7.0.4307.16141)
Cheers
Lachlan
Filed under: General ledger
emeadaxsupport: AX for Retail: Size Barcode setup and creation with number sequence Blog bot DAX Blogs 0 12.02.2015 01:12
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Часовой пояс GMT +3, время: 16:46.
