Старый 08.09.2016, 09:11   #1
organicax: Lean production flow for simple manufacturing step
Источник: https://organicax.com/2016/09/07/lea...acturing-step/
In the setting up lean in AX you will need to create a production flow which defines the activities that you would go through to manufacture a product. You can correlate a activity to a step in a manufacturing route. So it’s a new concept to setup if you are investigating lean in AX. You will need to provide similar details like where does the work get done which is a work center, how long it will take etc. In lean conversion work gets done in a process activity and moving materials in a transfer activity. Because the concepts a little different to a route this is a quick overview to familiarize with the basic setup options and we’ll investigate the parameters in further posts.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
axmfg: Lean manufacturing: Picking activities and kanban line events Blog bot DAX Blogs 0 26.08.2014 21:13
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Microsoft Dynamics AX 2012 White Paper: Lean Manufacturing - Production Flows and Activities Vadik DAX: База знаний и проекты 1 31.07.2011 18:37
Часовой пояс GMT +3, время: 12:45.
