emeadaxsupport: Microsoft Dynamics AX 2012 Upgrade – Using the State Transfer Tool with AX 2009, you can potentially have duplicate records created within table Shadow_DirPartyRelationship
Источник: http://blogs.msdn.com/b/axsupport/ar...ationship.aspx
============== This specific issue occurs only when using the state transfer tool in AX 2009. The problem is as follows:
Workaround After running the state transfer in production, and before you continue with the upgrade you can run the following SQL statement to update the NextVal in table SystemSequences to fix this problem: UPDATE SYSTEMSEQUENCESYou need to restart the AOS Service after running the update statement above. Источник: http://blogs.msdn.com/b/axsupport/ar...ationship.aspx
