Старый 31.05.2014, 00:14   #1
emeadaxsupport: MS Dynamics AX 2012 R2 hardware sizing
Источник: http://blogs.msdn.com/b/axsupport/ar...re-sizing.aspx
If you are looking for Information here the following hints might be of interest:
We have the following Benchmark report available. That was performed based on MS Dynamic 2012 R1 but in terms of the sizing results things remained the same so it is still valid.
Important note: The tests in the Benchmark Report were performed on "standard" solution without any branch or ISV solutions or other customizations which can have a big impact on performance!
https://mbs.microsoft.com/partnersou...enchmarkpapers
Within the MS Dynamics Lifecycle Services (https://lcs.dynamics.com) there is a tool called Usage Profiler which can help you with sizing tasks. If you like please have a look here:
https://mbs.microsoft.com/partnersou...vicesavailable
Also the following presentation from Informationsource portal can help you in terms of the sizing topic:
a) MS Dynamics AX 2012 Performance, Benchmarks, Features & Patterns:
https://informationsource.dynamics.c...M76642V-8-1423
b) MS Dynamics AX 2012: Solution Architecture:
https://informationsource.dynamics.c...M76642V-8-1048
c) MS Dynamics AX 2012: Solution Architecture Best Practise:
https://informationsource.dynamics.c...M76642V-8-1497
emeadaxsupport: AX Content: How to install CU7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.11.2013 01:12
emeadaxsupport: Unexpected Compiler Errors installing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 07.11.2013 06:11
emeadaxsupport: AX for Retail 2012 R2: Run-down on Log Files Blog bot DAX Blogs 0 21.06.2013 08:11
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
dynamics-community.at: Dynamics AX 2012 Trainings Blog bot DAX auf Deutsch 0 19.06.2012 18:11
Часовой пояс GMT +3, время: 22:28.
