Старый 30.05.2013, 13:05   #1
Swordec is offline
Swordec
Пакетная печать документов в Excel
Microsoft Dynamics Ax 2012
Добрый день. Кто нибудь настраивал пакетную печать документов в Excel?
При попытке сделать разноску накладной и затем вывести ее на печать с помощью пакетной обработки, выдает ошибку:
Microsoft.Dynamics.Ax.Xpp.InvalidRemoteCallException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.InvalidRemoteCallException' was thrown.
at Dynamics.Ax.Application.XMLExcelReport_TORG12_RU.construct()
at Dynamics.Ax.Application.SalesPurchReport_Invoice_RU.Run() in SalesPurchReport_Invoice_RU.run.xpp:line 12
at Dynamics.Ax.Application.SalesPurchReport_RU.executeWithPrintMgmtTorg12M15(Args _args, PrintMgmtPrintSettingDetail _settingDetail, Int64 _recordId) in SalesPurchReport_RU.executeWithPrintMgmtTorg12M15.xpp:line 50
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.Executenonssrsreport(PrintMgmtPrintSettingDetail _setting) in NonSSRSPrintMgmtAdapter.executeNonSSRSReport.xpp:line 14
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.Outputreports() in NonSSRSPrintMgmtAdapter.outputReports.xpp:line 14
at Dynamics.Ax.Application.SalesInvoiceNonSSRSPrintMgmtAdapter.Runprintmgmt() in SalesInvoiceNonSSRSPrintMgmtAdapter.runPrintMgmt.xpp:line 43
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.runPrintMgmtNonSSRS(PrintMgmtDocumentType _printMgmtDocumentType, Args _args) in NonSSRSPrintMgmtAdapter.runPrintMgmtNonSSRS.xpp:line 25
at Dynamics.Ax.Application.SalesInvoiceController.main(Args _args) in SalesInvoiceController.main.xpp:line 21
at SalesInvoiceController::Main(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.MenuFunction.Run(xArgs _args, Boolean ) in MenuFunction.run.xpp:line 76
at Dynamics.Ax.Application.CustInvoiceJour.Printjournal(SalesInvoiceJournalPrint journalPrint, RecordSortedList journalList, NoYes copy, NoYes parmPrintFormLetter, NoYes parmPrintAcceptanceReport, NoYes parmPrintBillOfLading, NoYes parmPrintInventBaileeReport, NoYes parmPrintTransportInvoice, Boolean , Boolean , Boolean , Boolean , Boolean , Boolean , Boolean , Boolean ) in CustInvoiceJour.printJournal.xpp:line 104
at Dynamics.Ax.Application.SalesInvoiceJournalPrint.Doprint() in SalesInvoiceJournalPrint.doPrint.xpp:line 7
at Dynamics.Ax.Application.FormletterJournalPrint.Printjournal(Set _journalList) in FormletterJournalPrint.printJournal.xpp:line 34
at Dynamics.Ax.Application.SalesInvoiceJournalPrint.Printjournal(Set _journalList) in SalesInvoiceJournalPrint.printJournal.xpp:line 13
at Dynamics.Ax.Application.FormletterService.Printjournal() in FormletterService.printJournal.xpp:line 33
at Dynamics.Ax.Application.FormletterService.Printout() in FormletterService.printOut.xpp:line 11
at Dynamics.Ax.Application.FormletterService.Endposting(Printout _printout) in FormletterService.endPosting.xpp:line 14
at Dynamics.Ax.Application.FormletterService.Endpostingmultithread() in FormletterService.endpostingMultithread.xpp:line 25
at Dynamics.Ax.Application.FormletterServiceEndBatchTask.Run() in FormletterServiceEndBatchTask.run.xpp:line 12
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at BatchIL.taskThreadEntry(Object threadArg)
ax2012, cil, excel, open xml, баг, ошибка, пакетная обработка, пакетный сервер
Двухсторонняя печать в Excel EfimV DAX: Программирование 2 15.11.2010 13:26
Печать страниц Excel на отдельные листы kuvg DAX: Программирование 3 02.08.2010 10:55
Запрет на печать и сохранение документов doc, xls. 3oppo DAX: Программирование 23 27.05.2010 17:07
Печать документов по Заказам, Закупкам Swetik DAX: Функционал 8 11.04.2008 20:07
Печать отчета в Excel. Axapta 3.0 Fedr Kuzmich DAX: Функционал 2 19.05.2004 18:26
Часовой пояс GMT +3, время: 10:16.
