Старый 28.03.2013, 08:59   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Microsoft Dynamics AX 2012 White Paper: Introduction to the SysOperation Framework
Overview
The SysOperation framework enables application logic to be written in a way that supports running interactively or via the batch server in Microsoft Dynamics AX 2012. This white paper illustrates how the SysOperation framework can be used to build operations that can run asynchronously and make use of the full processing power available on the server. Four code samples are presented and explained to illustrate the comparison between the SysOperation and the RunBaseBatch framework, and to demonstrate the use of the SysOperation framework in building asynchrouous and scalable operations.
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: mazzy (2), sukhanchik (2), alex55 (1).
ax2012, runbase, runbasebatch, sysoperation framework
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
AIF: Microsoft Dynamics AX 2012 Services and AIF White Papers Blog bot DAX Blogs 0 16.06.2011 00:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 20:40.
