Старый 26.03.2012, 07:11   #1
axinthefield: Lean Manufacturing in Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axinthefield...s-ax-2012.aspx
I recently spent some time digging into Lean Manufacturing in AX 2012, so I thought I’d post a few notes and some information about lean concepts in AX 2012. Overall, I think it looks great and appears to work well in mixed mode. You can use lean kanbans and production orders even within the same bill of materials.
Here are a few high level concepts that help describe lean functionality in AX 2012:
Production Flow –
  • For those familiar with previous functionality with Dynamics AX discrete manufacturing (production orders), you could compare Production flow to a Route, although there are significant differences.
  • The production flow contains activities performed by Work Cells. Activities can either be transfer (move inventory) or process (value add) activities.
  • You define all of the possible sequences for those activities by defining predecessors and successors for each activity.
  • A production flow could contain all activities from the very first on the lowest level semi-finished item, all the way up to the final activity on the finished good.
  • On each activity, you determine whether inventory is picked or produced. You have the option to do neither. An activity can simply be continuation of WIP.
Kanban rules
  • This is where a series of activities from the production flow are assigned to an item (semi-finished or finished).
  • That specific series of activities is referred to as a kanban flow.
  • The kanban rules determine how and when AX will generate kanban orders to replenish demand. The options are
    • Event-based(automatic or periodic) - Sales line, BOM line, Kanban line, Minimum, Stock replenishment
    • Scheduled (via MRP) – using standard MRP rules and logic
    • Fixed quantity – Always maintain static number of active kanbans
Kanban
  • As far as AX is concerned, I just view a kanban as an order. You process the kanban in order to satisfy the demand from which it was created.
  • There is a kanban board for both process and transfer jobs. There is a separate board for each work cell. It’s a clean and friendly user interface. You can simply select the job and mark it as complete, or you can record a start and a complete, pick raw material, etc.
  • There’s also a separate scheduling board where jobs can be moved around (drag and drop). It’s much nicer than the gantt chart.
A few key discoveries
  • Circular flows are not allowed
  • Alternative activities require multiple kanban rules. Example – if your second activity is subcontracted, and could be done by several different vendors, you would not be able to start the first activity, then select which vendor is going to do step 2. You’d have to either know before starting the first activity, or set up your flows such that the subcontracted activity is a new kanban rule, separated from the first activity. That way, you could choose an alternate vendor (kanban rule) before the 2nd activity is started. I may post a separate entry on this topic if there is interest.
  • Any item managed by kanbans must be standard cost
За это сообщение автора поблагодарили: fed (3), Innokentiy (1).
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 23:32.
